ONTAP FlexArray
存储错误会显示相关消息及其解决方法
贡献者
在标记错误条件时 storage errors show 、您需要确定发生错误的原因以及如何修复错误。
下表列出了检测到的后端配置错误 storage errors show 、并提供了有关每个错误的原因及其解决方法的详细信息。
storage errors show 消息 有关此消息的详细信息、请参见…​
NAME (Serial #): All paths to this array LUN are connected to the same fault domain. This is a single point of failure`(英文)
NAME (Serial #), port WWPN1: LUN 1 occurs more than once. LUNs cannot be reused on the same array target port(英文)
NAME (Serial #): This array LUN is an access control LUN. It is not supported and should be masked off or disabled`(英文)
NAME (Serial #) This array LUN is configured with conflicting failover modes. Each path to this LUN must use the same mode(英文)
NAME (Serial #): This Array LUN is only available on one path. Proper configuration requires two paths(英文)
NAME (Serial #): This array LUN is too large and is not usable. The maximum array LUN size supported is xTB(英文)
NAME (Serial #): This array LUN is too small and is not usable. The minimum array LUN size supported is 1GB(英文)
NAME (Serial #): This Array LUN is using multiple LUN IDs. Only one LUN ID per serial number is supported(英文)
卷集寻址不一致
NAME (Serial #): This array LUN is marked foreign and has a reservation(英文)
