所需的最小 ONTAP 权限
所需的最小 ONTAP 权限因用于数据保护的 SnapCenter 插件而异。
所有 SnapCenter 插件都需要以下最低权限。
| all-access 命令: ONTAP 8.3 及更高版本所需的最低权限 |
event generate-autosupport-log |
作业历史记录显示作业停止 |
LUN lun create lun delete lun igroup add lun igroup create lun igroup delete lun igroup rename lun igroup show lun mapping add-reporting-nodes lun mapping remove reporting-nodes lun mapping show lun modify lun move-in-volume lun offline lun persist-reservation clear lun lun serial resize lun serial lun show |
snapmirror list-destinations snapmirror policy add-rule snapmirror policy modify-rule snapmirror policy remove-rule snapmirror policy show snapmirror restore snapmirror show snapmirror show-history snapmirror update snapmirror update-ls-set |
version |
volume clone create volume clone show volume clone split start volume clone split stop volume create volume destroy volume file clone create volume file show-disk-usage volume offline volume modify volume qtree create volume qtree delete volume qtree modify volume qtree show volume restrict volume show volume show volume show volume show volume snapshot create volume snapshot delete volume snapshot modify volume snapshot rename volume snapshot restore volume snapshot restore-file volume snapshot show volume unmount |
vserver cifs vserver cifs share create vserver cifs share delete vserver cifs ShadowCopy show vserver cifs share show vserver cifs show vserver export-policy vserver export-policy delete vserver export-policy rule create vserver export-policy rule show vserver export-policy show vserver iscsi vserver iscsi vserver iscsi connection show vserver show network interface. network interface failover-groups network interface show |
| 只读命令: ONTAP 8.3 及更高版本所需的最低权限 |
vserver |
其他 ONTAP 信息
如果您运行的是 ONTAP 8.2.x :
您必须以
vsadmin的身份登录到 Storage VM 上,以获得适用于 VMware vSphere 的 SnapCenter 插件操作的适当特权。 -
如果您运行的是 ONTAP 8.3 及更高版本:
您必须以
vsadmin或具有上表中列出的最低权限的角色登录。
