SCV 所需的最低 ONTAP 权限
所需的最小 ONTAP 权限因用于数据保护的 SnapCenter 插件而异。
从适用于VMware的SnapCenter插件(SCV) 5.0开始、您需要添加HTTP和ONTAPI类型的应用程序、作为对SCV具有基于角色的自定义访问权限的任何ONTAP用户的用户登录方法。如果无法访问这些应用程序、备份将失败。您需要重新启动选择控制阀服务才能识别对ONTAP用户登录方法所做的更改。 |
所需的最小 ONTAP 权限
所有 SnapCenter 插件都需要以下最低权限。
完全访问命令:最小ONTAP Privileges。 |
event generate-autosupport-log |
作业历史记录显示 |
LUN lun create lun delete lun igroup add lun igroup create lun igroup delete lun igroup rename lun igroup show lun mapping add-reporting-nodes lun mapping remove reporting-nodes lun mapping show lun modify lun move-in-volume lun offline lun persist-reservation clear lun lun serial resize lun serial lun show |
snapmirror list-destinations snapmirror policy add-rule snapmirror policy modify-rule snapmirror policy remove-rule snapmirror policy show snapmirror restore snapmirror show snapmirror show-history snapmirror update snapmirror update-ls-set |
version |
volume clong create volume clong show volume clone-split start volume clone-split status volume clone-split stop volume create volume delete volume销毁volume file clone-disk usage-volume脱机卷联机卷管理的功能卷修改卷qtree create volume qtree delete volume qtree修改SnapLock卷qtree show volume resystem show volume snapshot create volume snapshot delete volume snapshot修改卷快照 |
vserver cifs vserver export-policy vserver export-policy create vserver export-policy delete vserver export-policy rule create vserver export-policy rule show vserver export-policy show vserver iscsi vserver nvme subsystem controller vserver nvme subsystem controller show vserver nvme subsystem create vserver nvme subsystem delete vserver nvme subsystem host vserver nvme subsystem host show vserver nvme subsystem host add vserver nvme subsystem host remove vserver nvme subsystem map vserver nvme subsystem map show vserver nvme subsystem map add vserver nvme subsystem map remove vserver nvme subsystem modify vserver nvme subsystem show vserver nvme namespace create vserver nvme namespace delete vserver nvme namespace modify vserver nvme namespace show network interface |
| 只读命令:最小ONTAP Privileges |
cluster identity show network interface show vserver |
| 完全访问命令:最小ONTAP Privileges |
vserver consistency-group |
在创建要与数据SVserver关联的角色时、可以忽略_cluster Identity show_ cluster level命令。
您可以忽略有关不受支持的Vserver命令的警告消息。 |
其他 ONTAP 信息
要使用SnapMirror活动同步功能、您需要ONTAP 9.12.1或更高版本。
要使用防篡改Snapshot (TPS)功能:
SAN需要ONTAP 9.13.1.及更高版本
对于NFS、您需要ONTAP 9.12.1及更高版本
对于基于TCP的NVMe和基于FC的NVMe协议、您需要使用NVMe.10.1 ONTAP 9及更高版本。
从ONTAP版本 9.11.1 开始,与ONTAP集群的通信是通过 REST API 进行的。 ONTAP用户应该启用 http 应用程序。但是,如果发现ONTAP REST API 存在问题,配置键“FORCE_ZAPI”有助于切换到传统的 ZAPI 工作流程。您可能需要使用配置 API 添加或更新此密钥并将其设置为 true。请参阅知识库文章, "如何使用RestAPI编辑选择控制阀中的配置参数"了解更多信息。 |
