此產品有較新版本可以使用。
= Audit Message Reference
:icons: font
:imagesdir: ../media/
* link:audit_message_overview.html[Audit message overview]
** link:audit_message_flow_and_retention.html[Audit message flow and retention]
** link:changing_audit_message_levels.html[Changing audit message levels]
** link:accessing_audit_log_file.html[Accessing the audit log file]
** link:audit_log_file_rotation.html[Audit log file rotation]
* link:audit_file_and_message_formats.html[Audit log file and message formats]
** link:audit_log_file_format.html[Audit log file format]
*** link:using_audit_explain_tool.html[Using the audit-explain tool]
*** link:using_audit_sum_tool.html[Using the audit-sum tool]
** link:audit_message_format.html[Audit message format]
*** link:data_types.html[Data types]
*** link:event_specific_data.html[Event-specific data]
*** link:common_elements_in_audit_messages.html[Common elements in audit messages]
*** link:audit_message_examples.html[Audit message examples]
* link:audit_messages_and_object_lifecycle.html[Audit messages and the object lifecycle]
** link:object_ingest_transactions.html[Object ingest transactions]
*** link:example_s3_object_ingest.html[Example: S3 object ingest]
** link:object_delete_transactions.html[Object delete transactions]
*** link:example_s3_object_deletion.html[Example: S3 object deletion]
** link:object_retrieve_transactions.html[Object retrieve transactions]
*** link:example_s3_object_retrieval.html[Example: S3 object retrieval]
** link:metadata_update_messages.html[Metadata update messages]
*** link:example_s3_metadata_update.html[Example: S3 metadata update]
* link:audit_messages_main.html[Audit messages]
** link:audit_message_categories.html[Audit message categories]
*** link:system_audit_messages.html[System audit messages]
*** link:object_storage_audit_messages.html[Object storage audit messages]
*** link:client_read_audit_messages.html[Client read audit messages]
*** link:client_write_audit_messages.html[Client write audit messages]
*** link:management_audit_message.html[Management audit message]
** link:audit_messages_list.html[Audit messages]
*** link:apct_archive_purge_from_cloud_tier.html[APCT: Archive Purge from Cloud-Tier]
*** link:arcb_archive_object_retrieve_begin.html[ARCB: Archive Object Retrieve Begin]
*** link:arce_archive_object_retrieve_end.html[ARCE: Archive Object Retrieve End]
*** link:arct_archive_retrieve_from_cloud_tier.html[ARCT: Archive Retrieve from Cloud-Tier]
*** link:arem_archive_object_remove.html[AREM: Archive Object Remove]
*** link:asce_archive_object_store_end.html[ASCE: Archive Object Store End]
*** link:asct_archive_store_cloud_tier.html[ASCT: Archive Store Cloud-Tier]
*** link:atce_archive_object_store_begin.html[ATCE: Archive Object Store Begin]
*** link:avcc_archive_validate_cloud_tier_configuration.html[AVCC: Archive Validate Cloud-Tier Configuration]
*** link:cbrb_object_receive_begin.html[CBRB: Object Receive Begin]
*** link:cbre_object_receive_end.html[CBRE: Object Receive End]
*** link:cbsb_object_send_begin.html[CBSB: Object Send Begin]
*** link:cbse_object_send_end.html[CBSE: Object Send End]
*** link:ecoc_corrupt_erasure_coded_data_fragment.html[ECOC: Corrupt Erasure Coded Data Fragment]
*** link:etaf_security_authentication_failed.html[ETAF: Security Authentication Failed]
*** link:gnrg_gnds_registration.html[GNRG: GNDS Registration]
*** link:gnur_gnds_unregistration.html[GNUR: GNDS Unregistration]
*** link:gted_grid_task_ended.html[GTED: Grid Task Ended]
*** link:gtst_grid_task_started.html[GTST: Grid Task Started]
*** link:gtsu_grid_task_submitted.html[GTSU: Grid Task Submitted]
*** link:idel_ilm_initiated_delete.html[IDEL: ILM Initiated Delete]
*** link:lkcu_overwritten_object_cleanup.html[LKCU: Overwritten Object Cleanup]
*** link:llst_location_lost.html[LLST: Location Lost]
*** link:mgau_management_audit_message.html[MGAU: Management audit message]
*** link:olst_system_detected_lost_object.html[OLST: System Detected Lost Object]
*** link:orlm_object_rules_met.html[ORLM: Object Rules Met]
*** link:ovwr_object_overwrite.html[OVWR: Object Overwrite]
*** link:sadd_security_audit_disable.html[SADD: Security Audit Disable]
*** link:sade_security_audit_enable.html[SADE: Security Audit Enable]
*** link:scmt_object_store_commit.html[SCMT: Object Store Commit]
*** link:sdel_s3_delete.html[SDEL: S3 DELETE]
*** link:sget_s3_get.html[SGET: S3 GET]
*** link:shea_s3_head.html[SHEA: S3 HEAD]
*** link:spos_s3_post.html[SPOS: S3 POST]
*** link:sput_s3_put.html[SPUT: S3 PUT]
*** link:srem_object_store_remove.html[SREM: Object Store Remove]
*** link:supd_s3_metadata_updated.html[SUPD: S3 Metadata Updated]
*** link:svrf_object_store_verify_fail.html[SVRF: Object Store Verify Fail]
*** link:svru_object_store_verify_unknown.html[SVRU: Object Store Verify Unknown]
*** link:sysd_node_stop.html[SYSD: Node Stop]
*** link:syst_node_stopping.html[SYST: Node Stopping]
*** link:sysu_node_start.html[SYSU: Node Start]
*** link:vlst_user_initiated_volume_lost.html[VLST: User Initiated Volume Lost]
*** link:wdel_swift_delete.html[WDEL: Swift DELETE]
*** link:wget_swift_get.html[WGET: Swift GET]
*** link:whea_swift_head.html[WHEA: Swift HEAD]
*** link:wput_swift_put.html[WPUT: Swift PUT]
* link:copyright_and_trademark.html[Copyright, trademark, and machine translation]
** link:copyright.html[Copyright]
** link:trademark.html[Trademark]
** link:machine_translation_disclaimer.html[Machine translation]
