此產品有較新版本可以使用。
= Recovery and Maintenance Guide :icons: font :imagesdir: ../media/ * link:introduction_to_storagegrid_recovery_and_maintenance.html[Introduction to StorageGRID recovery and maintenance] ** link:web_browser_requirements.html[Web browser requirements] ** link:downloading_recovery_package.html[Downloading the Recovery Package] * link:storagegrid_hotfix_procedure.html[StorageGRID hotfix procedure] ** link:considerations_for_applying_hotfix.html[Considerations for applying a hotfix] ** link:hotfix_planning_and_preparation.html[Hotfix planning and preparation] *** link:how_your_system_is_affected_when_you_apply_hotfix.html[How your system is affected when you apply a hotfix] *** link:obtaining_required_materials_for_hotfix.html[Obtaining the required materials for a hotfix] *** link:downloading_hotfix_file.html[Downloading the hotfix file] *** link:checking_systems_condition_before_applying_hotfix.html[Checking the system's condition before applying a hotfix] ** link:applying_hotfix.html[Applying the hotfix] * link:grid_node_recovery_procedures.html[Grid node recovery procedures] ** link:warnings_and_considerations_for_grid_node_recovery.html[Warnings and considerations for grid node recovery] ** link:gathering_required_materials_for_grid_node_recovery.html[Gathering required materials for grid node recovery] *** link:downloading_and_extracting_storagegrid_installation_files.html[Downloading and extracting the StorageGRID installation files] ** link:selecting_node_recovery_procedure.html[Selecting a node recovery procedure] ** link:recovering_from_storage_node_failures.html[Recovering from Storage Node failures] *** link:recovering_storage_node_that_has_been_down_more_than_15_days.html[Recovering a Storage Node that has been down more than 15 days] *** link:recovering_storagegrid_appliance_storage_node.html[Recovering a StorageGRID appliance Storage Node] **** link:preparing_appliance_storage_node_for_reinstallation.html[Preparing an appliance Storage Node for reinstallation] **** link:starting_storagegrid_appliance_installation.html[Starting StorageGRID appliance installation] **** link:monitoring_storagegrid_appliance_installation_sn.html[Monitoring StorageGRID appliance installation] **** link:selecting_start_recovery_to_configure_appliance_storage_node.html[Selecting Start Recovery to configure an appliance Storage Node] **** link:remounting_and_reformatting_appliance_storage_volumes.html[Remounting and reformatting appliance storage volumes ("`Manual Steps`")] **** link:restoring_object_data_to_storage_volume_for_appliance.html[Restoring object data to a storage volume for an appliance] **** link:checking_storage_state_after_recovering_sga.html[Checking the storage state after recovering an appliance Storage Node] *** link:recovering_from_storage_volume_failure_where_system_drive_is_intact.html[Recovering from storage volume failure where the system drive is intact] **** link:reviewing_warnings_about_storage_volume_recovery.html[Reviewing warnings about storage volume recovery] **** link:identifying_and_unmounting_failed_storage_volumes.html[Identifying and unmounting failed storage volumes] **** link:recovering_failed_storage_volumes_and_rebuilding_cassandra_database.html[Recovering failed storage volumes and rebuilding the Cassandra database] **** link:restoring_object_data_to_storage_volume_where_system_drive_is_intact.html[Restoring object data to a storage volume where the system drive is intact] **** link:checking_storage_state_after_recovering_storage_volumes.html[Checking the storage state after recovering storage volumes] *** link:recovering_from_system_drive_failure.html[Recovering from system drive failure] **** link:reviewing_warnings_for_system_drive_recovery.html[Reviewing warnings for Storage Node system drive recovery] **** link:replacing_storage_node.html[Replacing the Storage Node] **** link:selecting_start_recovery_to_configure_storage_node.html[Selecting Start Recovery to configure a Storage Node] **** link:remounting_and_reformatting_storage_volumes_manual_steps.html[Remounting and reformatting storage volumes ("`Manual Steps`")] **** link:restoring_object_data_to_storage_volume_if_required.html[Restoring object data to a storage volume, if required] **** link:checking_storage_state_after_recovering_storage_node_system_drive.html[Checking the storage state after recovering a Storage Node system drive] ** link:recovering_from_admin_node_failures.html[Recovering from Admin Node failures] *** link:recovering_from_primary_admin_node_failures.html[Recovering from primary Admin Node failures] **** link:copying_audit_logs_from_failed_primary_admin_node.html[Copying audit logs from the failed primary Admin Node] **** link:replacing_primary_admin_node.html[Replacing the primary Admin Node] **** link:configuring_replacement_primary_admin_node.html[Configuring the replacement primary Admin Node] **** link:restoring_audit_log_on_recovered_primary_admin_node.html[Restoring the audit log on the recovered primary Admin Node] **** link:resetting_preferred_sender_on_recovered_primary_admin_node.html[Resetting the preferred sender on the recovered primary Admin Node] **** link:restoring_admin_node_database_primary_admin_node.html[Restoring the Admin Node database when recovering a primary Admin Node] **** link:restoring_prometheus_metrics_primary_admin_node.html[Restoring Prometheus metrics when recovering a primary Admin Node] *** link:recovering_from_non_primary_admin_node_failures.html[Recovering from non-primary Admin Node failures] **** link:copying_audit_logs_from_failed_non_primary_admin_node.html[Copying audit logs from the failed non-primary Admin Node] **** link:replacing_non_primary_admin_node.html[Replacing a non-primary Admin Node] **** link:selecting_start_recovery_to_configure_non_primary_admin_node.html[Selecting Start Recovery to configure a non-primary Admin Node] **** link:restoring_audit_log_on_recovered_non_primary_admin_node.html[Restoring the audit log on the recovered non-primary Admin Node] **** link:resetting_preferred_sender_on_recovered_non_primary_admin_node.html[Resetting the preferred sender on the recovered non-primary Admin Node] **** link:restoring_admin_node_database_non_primary_admin_node.html[Restoring the Admin Node database when recovering a non-primary Admin Node] **** link:restoring_prometheus_metrics_non_primary_admin_node.html[Restoring Prometheus metrics when recovering a non-primary Admin Node] ** link:recovering_from_gateway_node_failures.html[Recovering from Gateway Node failures] *** link:replacing_gateway_node.html[Replacing a Gateway Node] *** link:selecting_start_recovery_to_configure_gateway_node.html[Selecting Start Recovery to configure a Gateway Node] ** link:recovering_from_archive_node_failures.html[Recovering from Archive Node failures] *** link:replacing_archive_node.html[Replacing an Archive Node] *** link:selecting_start_recovery_to_configure_archive_node.html[Selecting Start Recovery to configure an Archive Node] *** link:resetting_archive_node_connection_to_cloud.html[Resetting Archive Node connection to the cloud] ** link:all_node_types_replacing_vmware_node.html[All grid node types: Replacing a VMware node] ** link:all_node_types_replacing_linux_node.html[All grid node types: Replacing a Linux node] *** link:deploying_new_linux_hosts.html[Deploying new Linux hosts] *** link:restoring_existing_nodes.html[Restoring grid nodes to the host] **** link:restoring_and_validating_grid_nodes.html[Restoring and validating grid nodes] ***** link:fixing_mssing_network_interface_errors.html[Fixing missing network interface errors] ***** link:fixing_missing_block_device_errors.html[Fixing missing block device errors] **** link:starting_storagegrid_host_service.html[Starting the StorageGRID host service] **** link:recovering_nodes_that_fail_to_start_normally.html[Recovering nodes that fail to start normally] *** link:whats_next_performing_additional_recovery_steps_if_required.html[What's next: Performing additional recovery steps, if required] ** link:replacing_failed_node_with_services_appliance.html[Replacing a failed node with a services appliance] *** link:installing_services_appliance_platform_change_only.html[Installing a services appliance (platform change only)] *** link:preparing_appliance_for_reinstallation_platform_replacement_only.html[Preparing an appliance for reinstallation (platform replacement only)] *** link:starting_software_installation_on_services_appliance_recovery.html[Starting software installation on a services appliance] *** link:monitoring_services_appliance_installation.html[Monitoring services appliance installation] * link:how_site_recovery_is_performed_by_technical_support.html[How site recovery is performed by technical support] * link:decommission_procedure.html[Decommission procedure] ** link:grid_node_decommissioning.html[Grid node decommissioning] *** link:preparing_to_decommission_grid_nodes.html[Preparing to decommission grid nodes] **** link:considerations_for_decommissioning_grid_nodes.html[Considerations for decommissioning grid nodes] ***** link:considerations_for_decommissioning_admin_or_gateway_nodes.html[Considerations for decommissioning Admin Nodes or a Gateway Nodes] ***** link:considerations_for_decommissioning_storage_nodes.html[Considerations for decommissioning Storage Nodes] ****** link:understanding_adc_service_quorum.html[Understanding the ADC quorum] ****** link:reviewing_ilm_policy_and_storage_configuration.html[Reviewing the ILM policy and storage configuration] ****** link:decommissioning_disconnected_storage_nodes.html[Decommissioning disconnected Storage Nodes] ****** link:consolidating_storage_nodes.html[Consolidating Storage Nodes] ****** link:decommissioning_multiple_storage_nodes.html[Decommissioning multiple Storage Nodes] **** link:checking_data_repair_jobs.html[Checking data repair jobs] *** link:gathering_required_materials_node_decom.html[Gathering required materials] *** link:accessing_decommission_nodes_page.html[Accessing the Decommission Nodes page] *** link:decommissioning_disconnected_grid_nodes.html[Decommissioning disconnected grid nodes] *** link:decommissioning_connected_grid_nodes.html[Decommissioning connected grid nodes] *** link:pausing_and_resuming_decommission_process_for_storage_nodes.html[Pausing and resuming the decommission process for Storage Nodes] *** link:troubleshooting_node_decommissioning.html[Troubleshooting node decommissioning] ** link:site_decommissioning.html[Site decommissioning] *** link:considerations_for_removing_site.html[Considerations for removing a site] *** link:gathering_required_materials_site_decom.html[Gathering required materials] *** link:step_1_select_site.html[Step 1: Select Site] *** link:step_2_view_details.html[Step 2: View Details] *** link:step_3_revise_ilm_policy.html[Step 3: Revise ILM Policy] *** link:step_4_remove_ilm_references.html[Step 4: Remove ILM References] *** link:step_5_resolve_node_conflicts.html[Step 5: Resolve Node Conflicts (and start decommission)] *** link:step_6_monitor_decommission.html[Step 6: Monitor Decommission] * link:network_maintenance_procedures.html[Network maintenance procedures] ** link:updating_subnets_for_grid_network.html[Updating subnets for the Grid Network] ** link:configuring_ip_addresses.html[Configuring IP addresses] *** link:changing_nodes_network_configuration.html[Changing a node's network configuration] *** link:adding_to_or_changing_subnet_lists_on_admin_network.html[Adding to or changing subnet lists on the Admin Network] *** link:adding_to_or_changing_subnet_lists_on_grid_network.html[Adding to or changing subnet lists on the Grid Network] *** link:linux_adding_interfaces_to_existing_node.html[Linux: Adding interfaces to an existing node] *** link:changing_ip_addresses_and_mtu_values_for_all_nodes_in_grid.html[Changing IP addresses for all nodes in the grid] ** link:configuring_dns_servers.html[Configuring DNS servers] *** link:modifying_dns_configuration_for_single_grid_node.html[Modifying the DNS configuration for a single grid node] ** link:configuring_ntp_servers.html[Configuring NTP servers] ** link:restoring_network_connectivity_for_isolated_nodes.html[Restoring network connectivity for isolated nodes] * link:host_level_and_middleware_procedures.html[Host-level and middleware procedures] ** link:linux_migrating_grid_node_to_new_host.html[Linux: Migrating a grid node to a new host] *** link:linux_exporting_node_from_source_host.html[Linux: Exporting the node from the source host] *** link:linux_importing_node_on_target_host.html[Linux: Importing the node on the target host] *** link:linux_starting_migrated_node.html[Linux: Starting the migrated node] ** link:archive_node_maintenance_for_tsm_middleware.md#archive_node_maintenance_for_tsm_middleware[Archive Node maintenance for TSM middleware] ** link:wmware_configuring_virtual_machine_for_automatic_restart.html[VMware: Configuring a virtual machine for automatic restart] * link:grid_node_procedures.html[Grid node procedures] ** link:viewing_server_manager_status_and_version.html[Viewing Server Manager status and version] ** link:viewing_current_status_of_all_services.html[Viewing current status of all services] ** link:starting_server_manager_and_all_services.html[Starting Server Manager and all services] ** link:restarting_server_manager_and_all_services.html[Restarting Server Manager and all services] ** link:stopping_server_manager_and_all_services.html[Stopping Server Manager and all services] ** link:viewing_current_status_of_service.html[Viewing current status of a service] ** link:stopping_service.html[Stopping a service] ** link:placing_appliance_into_maintenance_mode.html[Placing an appliance into maintenance mode] ** link:forcing_service_to_terminate.html[Forcing a service to terminate] ** link:starting_or_restarting_service.html[Starting or restarting a service] ** link:removing_port_remaps.html[Removing port remaps] ** link:removing_port_remaps_on_bare_metal_hosts.html[Removing port remaps on bare metal hosts] ** link:rebooting_grid_node.html[Rebooting a grid node] *** link:rebooting_grid_node_from_grid_manager.html[Rebooting a grid node from the Grid Manager] *** link:rebooting_grid_node_from_command_shell.html[Rebooting a grid node from the command shell] ** link:shutting_down_grid_node.html[Shutting down a grid node] ** link:powering_down_host.html[Powering down a host] ** link:powering_off_and_on_all_nodes_in_grid.html[Powering off and on all nodes in the grid] *** link:stopping_services_and_shutting_down_grid_nodes.html[Stopping services and shutting down grid nodes] *** link:powering_on_grid_nodes.html[Starting up the grid nodes] ** link:using_donotstart_file.html[Using a DoNotStart file] *** link:adding_donotstart_file_for_service.html[Adding a DoNotStart file for a service] *** link:removing_donotstart_file_for_service.html[Removing a DoNotStart file for a service] ** link:troubleshooting_server_manager.html[Troubleshooting Server Manager] *** link:accessing_server_manager_log_file.html[Accessing the Server Manager log file] *** link:service_with_error_state.html[Service with an error state] * link:appliance_node_cloning.html[Appliance node cloning] ** link:how_appliance_node_cloning_works.html[How appliance node cloning works] ** link:considerations_and_requirements_for_appliance_node_cloning.html[Considerations and requirements for appliance node cloning] ** link:appliance_node_cloning_procedure.html[Appliance node cloning procedure] * link:copyright_and_trademark.html[Copyright, trademark, and machine translation] ** link:copyright.html[Copyright] ** link:trademark.html[Trademark] ** link:machine_translation_disclaimer.html[Machine translation]
