BlueXP operational resiliency
Remediate the issue automatically
Contributors amgrissino netapp-bcammett
If you selected the Remediate option in BlueXP operational resiliency, the service can implement the remediation for you.
Steps
  1. From the BlueXP left navigation, select Health > Operational resiliency > Risk Remediation.
  2. From the Risk Remediation page, sort by the Impact level column to see the highest risks first.
  3. Select the risk and select Remediate risk.
  4. For each cluster, select Remediate.
    Instructions appear, depending on the issue. Some of the options on this page do not appear if a BlueXP Connector exists or a cluster is known.
    • If a Connector does not exist or is not yet enabled, the service displays the Create a Connector page, where you can create the Connector. If the Connector exists, but is not active, you must enable it in the Cloud provider service.
      Refer to the BlueXP documentation that describes how to create a Connector.
    • If a cluster does not exist, the service displays a page where you identify the cluster.
      Refer to BlueXP documentation that explains how to identify the cluster.
  5. After the Connector is deployed and the cluster is discovered, review the remediation.
    If you selected the Remediate option to have the service implement the remediation for you, the Review and Execute Required Fix page appears.
  6. Review the risk and other information.
  7. Select Execute.
    This action deploys the Connector (if not already done), discovers the cluster, downloads the fix and automatically implements the fix on the selected cluster.
  8. To view the status of the remediation fix, note the cluster name on the Remediation Status page.
