Astra Automation
Modify a hook source
Colaboradores
PUT /accounts/{account_id}/core/v1/hookSources/{hookSource_id}
Replaces the entire stored resource with the supplied JSON request body while preserving key values that are not user-modifiable.
Side Effects
  • Updating an existing source hook will immediately impact any future snapshots of applications that have matching execution hooks that use the updated source hook resource.
  • The MD5 checksum is computed on the value of the "source" field and set as the value of the "sourceMD5Checksum" field.
account_id
string
path
True
  • example: {{.Account}}
hookSource_id
string
path
True
ID of the hookSource collection to list
Request Body
Side Effects
type
string
True
  • "application/astra-hookSource"
version
string
True
  • "1.0"
id
string
False
name
string
False
JSON string containing a user-specified name for the resource. Defined values are:
  • Minimum length: 1
  • Maximum length: 63 The name is required to be unique within all hook source resources.
private
string
False
JSON string indicating whether the source field will be exposed in APIs or be intentionally left blank. Defined values are:
  • "true" - The source value is private and will not be exposed through the API.
  • "false" - The source value is not private and will be exposed through the API.
preloaded
string
False
JSON string that indicates whether the source was preloaded. Defined values are:
  • "true" - The source was preloaded.
  • "false" - The source was not preloaded. Preloaded hook source resources are read only.
sourceType
string
False
JSON string defining the hook source type. Defined values are:
  • "script" - Shell script. The plaintext source must not contain binary data or carriage-return characters, otherwise, an error is returned.
source
string
False
JSON string containing the script to be run in base64 format. Defined values are:
  • Minimum length: 0
  • Maximum length: 131072
  • Conforms to the base64 Encoded Data Schema The maximum size of a source value is 128 KiB when encoded using base64.
sourceMD5Checksum
string
False
JSON string containing the MD5 checksum computed for the value of the "source" key. Defined values are:
  • Defined regex is: "^([0-9a-fA-F]){32}$"
description
string
False
JSON string containing a user-specified description of the hook source. Defined values are:
  • Minimum length: 0
  • Maximum length: 511
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-hookSource",
  "version": "1.0",
  "source": "ZWNobyAiVkhKaGJuTWdVbWxuYUhSeklRPT0iIHwgYmFzZTY0IC1k",
  "description": "Pre and post hook script for order processing v2"
JSON
Status: 204, Indicates if the hookSource resource was updated.
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
JSON
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
JSON
Status: 409, Conflict
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
JSON
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
JSON
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "type": "https://astra.netapp.io/problems/1",
  "title": "Resource not found",
  "detail": "The resource specified in the request URI wasn't found.",
  "status": "404"
JSON
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
modificationTimestamp
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
