Manage working environments
The Working environments table include various environmental parameters that help in identifying the cluster that can be moved to more efficient storage. You can add or remove the environmental parameters to customize the Working environments table.
You can analyze the sustainability score at cluster level. You can also implement the recommended actions at cluster level of your installed base to improve the cluster-level sustainability score. For more information, see Improve sustainability score at cluster level.
To customize and gain a better understanding of the Working environments table, follow these steps:
Go to Sustainability from the Governance category available in the BlueXP left navigation.
Go to the Working environments table.
You can add or remove the environmental parameters to customize the Working environments table using the
icon.
You can view the sustainability score at cluster level, select the cluster name to access ClusterViewer, take specific recommended actions from here to improve the sustainability score at cluster level. For more information, see Improve sustainability score at cluster level.
You can select Enable Monitoring from the Real-time power column to view the real-time power details at the cluster level. For more information, see Cloud Insights.
You can export this table in comma-separated values (.csv) format using the
icon.
Go to Sustainability from the STORAGE HEALTH category available in the left navigation of Digital Advisor dashboard.
icon.
icon.
