Common ONTAP features supported on ASA r2 systems
Because ASA r2 systems run a streamlined version of ONTAP, you perform many common ONTAP tasks and System Manager functions the same way as on other ONTAP systems.
For more information about common features and functions, see the following ONTAP documentation.
AutoSupport
Beginning with ONTAP 9.20.1, System Manager displays AutoSupport alerts if AutoSupport is configured for the SMTP protocol instead of the HTTPs protocol, if AutoSupport is disabled but customer and partner email recipients remain configured and if an AutoSupport transmission fails because of a DNS issue.
Data protection
Learn more about common data protection features supported on ASA r2 systems.
Clustered external key servers
You can configure connectivity to clustered external key management servers on a storage VM. With clustered key servers, you can designate primary and secondary key servers on a storage VM. When registering keys, ONTAP first tries a primary key server and then sequentially tries secondary servers until the operation succeeds, preventing duplicate keys.
External key management for encryption at rest
You can use one or more KMIP servers to secure the keys the cluster uses to access encrypted data.
Beginning with ONTAP 9.20.1, when you enable an external key manager on a data storage VM, ONTAP automatically migrates that storage VM's volume encryption keys from the admin-scope key manager to the new data storage VM key manager. This simplifies the transition to external key management and removes the need for a separate manual migration step in the standard workflow.
Data security
Learn more about common data security features supported on ASA r2 systems.
Administrator access management
The role assigned to an administrator determines which functions the administrator can perform. System Manager provides predefined roles for cluster administrators and storage VM administrators. You assign the role when you create the administrator’s account, or you can assign a different role later.
Client authentication and authorization
ONTAP uses standard methods to secure client and administrator access to storage and to protect against viruses. Advanced technologies are available for encryption of data at rest and for WORM storage. ONTAP authenticates a client machine and user by verifying their identities with a trusted source. ONTAP authorizes a user to access a file or directory by comparing the user's credentials with the permissions configured on the file or directory.
FC-SP-3 authentication and encryption
Beginning with ONTAP 9.20.1, ONTAP supports Fibre Channel Security Protocol 3 (FC-SP-3) authentication and encryption on Broadcom secure HBAs with ASA r2 systems. FC-SP-3 support enables hardware-level end-to-end encryption and device authentication to protect data in flight between FC and NVMe/FC SAN hosts and ONTAP storage systems while aligning with T11 Fibre Channel security standards.
Multi-admin verification (MAV)
Beginning with ONTAP 9.20.1, MAV approval groups can include identity provider (IdP), Active Directory (AD), and LDAP (nsswitch) groups as approvers, in addition to individual administrators. Supported group types include Entra ID, ADFS, AD domain groups, and LDAP groups. Adding or removing users in the IdP, AD, or LDAP directory does not require any changes to the MAV configuration. Learn more about MAV.
OAuth 2.0 authentication
You can use the Open Authorization (OAuth 2.0) framework to control access to your ONTAP clusters. OAuth 2.0 restricts and controls access to protected resources using signed access tokens.
SAML authentication and administrator access
You can configure and enable Security Assertion Markup Language (SAML) authentication for web services. SAML authenticates users by an external Identity Provider (IdP) instead of the directory service providers such as Active Directory and LDAP.
SNMP
Beginning with ONTAP 9.20.1, ONTAP supports SHA-512 authentication for SNMPv3 users. This enhancement lets you use stronger SNMPv3 authentication for external SNMP clients and for switch monitoring, including switches that require SHA-512 authentication.
TLS hardware offload
You can offload Transport Layer Security (TLS) encryption and decryption for your entire cluster to supported Ethernet cards. This reduces CPU overhead and improves performance for systems using TLS.
Networking
Learn more about common networking features supported on ASA r2 systems.
FIPS compliance
ONTAP complies with Federal Information Processing Standards (FIPS) 140-2 for all SSL connections. You can turn SSL FIPS mode on and off, set SSL protocols globally, and turn off any weak ciphers such as RC4 within ONTAP.
Beginning with ONTAP 9.18.1 postquantum computing cryptographic algorithms are supported for SSL. These algorithms provide additional protection against potential future quantum computing attacks, and are available when SSL FIPS mode is disabled.
Link Aggregation Groups (LAGs)
An interface group, also known as a Link Aggregation Group (LAG), is created by combining two or more physical ports on the same node into a single logical port. The logical port provides increased resiliency, increased availability, and load sharing.
Performance
Learn more about common performance features supported on ASA r2 systems.
Modify default settings that control automatic QoS throughput ceiling increases
Adaptive and non-adaptive QoS policy groups temporarily increase a workload’s throughput ceiling by 50% for 1 second by default to respond to short-term demands for higher performance. Beginning with ONTAP 9.19.1, you can modify these settings. In ONTAP 9.18.1 and earlier, you cannot change them.
IPspace TCP performance
Beginning with ONTAP 9.19.1, ONTAP improves TCP data transfer performance over lossy, high-latency WAN links by integrating two loss-recovery features, PRR and RACK, into the ONTAP TCP stack. PRR is suitable for all networks and is enabled by default. RACK is suitable for congested networks with link speeds of approximately 25 Gigabits/second and is disabled by default.
SAN configuration
A storage area network (SAN) consists of a storage solution connected to hosts over a SAN transport protocol such as iSCSI or FC. You can configure your SAN so that your storage solution attaches to your hosts through one or more switches. If you are using iSCSI, you can also configure your SAN so that your storage solution attaches directly to your host without using a switch.
SAN direct attachment
Beginning with ONTAP 9.19.1, an FC switch is not required to establish connections between FC and FC-NVMe hosts and ONTAP storage. Hosts can be directly connected to FC adapter ports on ASA r2 systems. Direct-attachment capability can be especially valuable in remote sites and hybrid environments where simplicity is key.
SAN Protocols
ASA r2 systems support all SAN protocols (iSCSI, FC, NVMe/FC, NVMe/TCP).
Learn about the NVMe protocol .
Learn to configure NVMe copy offload.
Beginning with ONTAP 9.18.1, ONTAP supports NVMe copy offload. NVMe copy offload enables an NVMe host to offload copy operations from its CPU to the CPU of the ONTAP storage controller. The host can copy data from one NVMe namespace to another while reserving its CPU resources for application workloads.
Learn more about space allocation (unmap) for NVMe.
Beginning with ONTAP 9.16.1, space deallocation (also called “hole punching” and “unmap”) is enabled for NVMe namespaces by default. Space deallocation allows a host to deallocate unused blocks from namespaces to reclaim space.
Storage efficiency
Storage efficiency is the measure of how effectively a storage system uses available space by optimizing storage resources, minimizing wasted space, and reducing written data's physical footprint.
ONTAP provides various storage efficiency technologies that can help you optimize storage usage and reduce costs.
Data reduction rate (DRR)
Beginning with ONTAP 9.20.1, the storage efficiency data reduction rate (DRR) provides a more precise assessment of ONTAP storage efficiency space savings by including only reducible data. In ONTAP 9.19.1 and earlier, the DRR includes both reducible and non-reducible data.
Global deduplication
Beginning with ONTAP 9.19.1, global deduplication extends the existing ONTAP deduplication space savings at the storage unit level to the entire storage availability zone (SAZ). By eliminating duplicate data blocks across all the storage units in the SAZ, you can significantly improve storage efficiency and reduce total cost of ownership. Global deduplication requires no feature license, is enabled by default, integrates seamlessly with existing storage efficiency technologies, and operates transparently with minimal performance impact and without the need for administrative configuration.
System Manager
You can search for various actions, objects, and information topics in System Manager. You can also search table data for specific entries.
User password expiration alerts
Beginning with ONTAP 9.20.1, if the role associated with a user account is configured for password expiry alerts, the user receives a top-of-page banner alert in System Manager immediately after logging in, beginning 14 days before the password expires. The alert is updated each time the user logs in to show the number of days remaining until the password expires. You can configure expiry alerts when you add or edit an administrator role.
