Monitor cluster and storage unit utilization on ASA r2 storage systems
Contributors netapp-aherbin
Use ONTAP System Manager to monitor your storage utilization to ensure you have the storage capacity you need to serve current and future workloads.
Monitor cluster utilization
Regularly monitor the amount of storage consumed by your cluster to ensure that, if needed, you are prepared to expand the cluster capacity before running out of space.
Steps
  1. In System Manager, select Dashboard.
  2. Under Capacity, view the amount of physical used space and the amount of available space on your cluster.
    The data reduction ratio represents the amount of space saved through storage efficiency.
What's next?
If your cluster is running low on space or does not have the capacity to meet future demand, add new drives to your ASA r2 system to increase your storage capacity.
Monitor storage availability zone utilization
Each HA pair in an ASA r2 system uses a common pool of storage called a storage availability zone. The storage availability zone has access to all available disks in the storage system and is visible to both nodes in the HA pair. Monitoring the available space of your storage availability zones allows you to decrease usage or increase capacity as needed so that you do not experience failed workloads due to insufficient space.
If you have four or more nodes in your cluster, you can view the amount of space used by the storage availability zone for each HA pair. This metric is not available for two-node clusters.
Beginning with ONTAP 9.19.1, an alert is displayed in System Manager Insights if a storage availability zone in one of your ASA r2 system HA pairs nears capacity. Learn more about System Manager Insights.
Steps
  1. In System Manager, select Cluster; then select Overview.
    A summary of the storage availability zone utilization is displayed for each HA pair in the cluster.
  2. If you want more detailed metrics, select a specific storage availability zone.
    Under Overview, the capacity of the storage availability zone, the amount of used space, and the data reduction ratio are displayed.
    Under Storage units, a list of all the storage units in the storage availability zone is displayed.
What's next?
If your storage availability zone is running low on space, move storage units to another storage availability zone to balance the storage utilization across the cluster, delete snapshots to free up space, or add disks to your nodes to increase capacity.
Monitor storage unit utilization
Monitor the amount of storage consumed by a storage unit so that you can proactively increase the size of the storage unit based on your business needs.
Steps
  1. In System Manager, select Storage.
  2. Select the storage unit you want to monitor; then select Overview.
  3. Under Storage, view the following:
    • Size of your storage unit
    • Amount of used space
    • Data reduction ratio
    • Snapshot used
      Snapshot used represents the amount of storage used by snapshots.
What's next?
If your storage unit is nearing capacity, you should modify the storage unit to increase its size.
