Before you begin
Contributors dmp-netapp
You can use these workflows to create and maintain the infrastructure used with the Astra Control Center deployment model. In most case, the workflows can also be used with Astra Control Service.
Note These workflows can be expanded and enhanced by NetApp at any time and so you should review them periodically.
General preparation
Before using any of the Astra workflows, make sure to review Prepare to use the workflows.
Workflow categories
The infrastructure workflows are organized in different categories to make it easier to locate the one you want.
Category Description
Identity and access
These workflows allow you to manage identity and how Astra is accessed. The resources include users, credentials, and tokens.
Buckets
You can use these workflows to create and manage the S3 buckets used to store backups.
Storage
These workflows allow you to add and maintain storage backends and volumes.
Clusters
You can add managed Kubernetes clusters which allows you to protect and support the applications they contain.
