Create a new execution hook override resource for an app
Creates an execution hook override resource for an app, specifying the desired values for customization. Use this to tailor execution hooks according to specific application requirements.
HTTP method and endpoint
POST /accounts/{account_id}/k8s/v1/apps/{app_id}/executionHookOverrides
Usage notes
Indicates the desired values for the Execution Hook Override API resource to be created.
This operation is deprecated. |
account_id |
string |
path |
True |
app_id |
string |
path |
True |
ID of the containing app resource |
Request Body
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
executionHookID |
string |
True |
JSON string containing the ID of an execution hook. Defined values are:
enabled |
string |
True |
JSON string that indicates whether the execution hook is enabled for the specified application. Defined values are:
metadata |
False |
Example request
"type": "application/astra-executionHookOverride",
"version": "1.0",
"executionHookID": "eb863cc6-0d9a-454d-8ef7-81b7cac91929",
"enabled": "false"
Status: 201, Returns the newly created executionHookOverride resource in the JSON response body.
type |
string |
True |
version |
string |
True |
id |
string |
True |
executionHookID |
string |
True |
enabled |
string |
True |
appID |
string |
True |
JSON string containing the associated ID of the application with which the override is linked. Defined values are:
metadata |
True |
"version": "1.0",
"id": "c11af802-5e53-5897-8cd9-2de730494be3",
"enabled": "false",
"appID": "4b43c2f7-bffa-4f60-b595-d98a05b64bc9",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
