Create a custom pod security policy
Astra Control needs to create and manage Kubernetes pods on the clusters it manages. If your cluster uses a restrictive pod security policy that doesn't allow privileged pod creation or allow processes within the pod containers to run as the root user, you need to create a less restrictive pod security policy to enable Astra Control to create and manage these pods.
Steps
Create a pod security policy for the cluster that is less restrictive than the default, and save it in a file. For example:
apiVersion: policy/v1beta1 kind: PodSecurityPolicy metadata: name: astracontrol annotations: seccomp.security.alpha.kubernetes.io/allowedProfileNames: '*' spec: privileged: true allowPrivilegeEscalation: true allowedCapabilities: - '*' volumes: - '*' hostNetwork: true hostPorts: - min: 0 max: 65535 hostIPC: true hostPID: true runAsUser: rule: 'RunAsAny' seLinux: rule: 'RunAsAny' supplementalGroups: rule: 'RunAsAny' fsGroup: rule: 'RunAsAny'
Create a new role for the pod security policy.
kubectl-admin create role psp:astracontrol \ --verb=use \ --resource=podsecuritypolicy \ --resource-name=astracontrol
Bind the new role to the service account.
kubectl-admin create rolebinding default:psp:astracontrol \ --role=psp:astracontrol \ --serviceaccount=astracontrol-service-account:default
