Astra Control Center
Create a custom pod security policy
Contributors netapp-mwallis
Astra Control needs to create and manage Kubernetes pods on the clusters it manages. If your cluster uses a restrictive pod security policy that doesn't allow privileged pod creation or allow processes within the pod containers to run as the root user, you need to create a less restrictive pod security policy to enable Astra Control to create and manage these pods.
Steps
  1. Create a pod security policy for the cluster that is less restrictive than the default, and save it in a file. For example:
    apiVersion: policy/v1beta1
    kind: PodSecurityPolicy
    metadata:
      annotations:
        seccomp.security.alpha.kubernetes.io/allowedProfileNames: '*'
    spec:
      privileged: true
      allowPrivilegeEscalation: true
      allowedCapabilities:
      volumes:
      hostNetwork: true
      hostPorts:
      - min: 0
        max: 65535
      hostIPC: true
      hostPID: true
      runAsUser:
        rule: 'RunAsAny'
      seLinux:
        rule: 'RunAsAny'
      supplementalGroups:
        rule: 'RunAsAny'
      fsGroup:
        rule: 'RunAsAny'
    YAML
  2. Create a new role for the pod security policy.
    kubectl-admin create role psp:astracontrol \
        --verb=use \
        --resource=podsecuritypolicy \
        --resource-name=astracontrol
  3. Bind the new role to the service account.
    kubectl-admin create rolebinding default:psp:astracontrol \
        --role=psp:astracontrol \
        --serviceaccount=astracontrol-service-account:default
