Review capacity planning status
If storage assets in your environment are currently below or forecasted to be below the threshold of 90% capacity, the economic efficiency service identifies those as low-capacity resources and alerts you. Additionally, the economic efficiency service provides recommendations on whether you should tier data or obtain additional capacity.
You can review the following types of data to assist in the capacity issue resolution.
Platform
Country where asset is located
Current and forecasted capacity by month
Capacity utilization and percent
Latency trends
IOPS trends
From the BlueXP left navigation, select Governance > Economic efficiency > Capacity planning.
Select Evaluate Storage Options for the asset.
Choose one of the options:
Add Capacity: Continue by adding capacity.
Tier cold data: Continue by tiering cold data to cloud storage and freeing up storage.
No action needed: Continue by selecting no action and setting reminders to check again.
