Known limitations
Known limitations identify platforms, devices, or functions that are not supported by this release of the product, or that do not interoperate correctly with it. Review these limitations carefully.
General limitations
The following limitations apply to Cloud Volumes ONTAP in AWS and in Azure.
Maximum concurrent replication operations
The maximum number of concurrent SnapMirror or SnapVault transfers for Cloud Volumes ONTAP is 100 per node, regardless of the instance type or machine type.
Software updates must be completed by Cloud Manager
Upgrades of Cloud Volumes ONTAP must be completed from Cloud Manager. You should not upgrade Cloud Volumes ONTAP by using System Manager or the CLI. Doing so can impact system stability.
Cloud Volumes ONTAP deployment must not be modified from your cloud provider’s console
Changes to a Cloud Volumes ONTAP configuration from your cloud provider's console results in an unsupported configuration. Any changes to the Cloud Volumes ONTAP resources that Cloud Manager creates and manages can impact system stability and Cloud Manager's ability to manage the system.
Disks and aggregates must be managed from Cloud Manager
All disks and aggregates must be created and deleted directly from Cloud Manager. You should not perform these actions from another management tool. Doing so can impact system stability, hamper the ability to add disks in the future, and potentially generate redundant cloud provider fees.
SnapManager licensing limitation
SnapManager per-server licenses are supported with Cloud Volumes ONTAP. Per-storage system (SnapManager suite) licenses are not supported.
Unsupported ONTAP features
The following features are not supported with Cloud Volumes ONTAP:
Aggregate-level inline deduplication
Aggregate-level background deduplication
Disk maintenance center
Disk sanitization
Fibre Channel (FC)
Flash Pools
FlexCache
Infinite Volumes
Interface groups
Intranode LIF failover
MetroCluster
Multi-tenancy (only one data-serving SVM is supported)
RAID4, RAID-DP, RAID-TEC (RAID0 is supported)
Service Processor
SnapLock Compliance and Enterprise modes (only Cloud WORM is supported)
SnapMirror Synchronous
VLANs
Known limitations in AWS
The following known limitations affect Cloud Volumes ONTAP in AWS.
Flash Cache limitations
C5D and R5D instance types include local NVMe storage, which Cloud Volumes ONTAP uses as Flash Cache. Note the following limitations:
Compression must be disabled on all volumes to take advantage of the Flash Cache performance improvements.
You can choose no storage efficiency when creating a volume from Cloud Manager, or you can create a volume and then disable data compression by using the CLI.
Cache rewarming after a reboot is not supported with Cloud Volumes ONTAP.
False alarms reported by Amazon CloudWatch
Cloud Volumes ONTAP does not release CPUs when idle, so Amazon CloudWatch can report a high CPU warning for the EC2 instance because it sees 100% usage. You can ignore this alarm. The ONTAP statistics command displays the true usage of the CPUs.
Cloud Volumes ONTAP HA pairs do not support immediate storage giveback
After a node reboots, the partner must sync data before it can return the storage. The time that it takes to resync data depends on the amount of data written by clients while the node was down and the data write speed during the time of giveback.
Limitations in the AWS C2S environment
View limitations in the Cloud Manager docs: Get started in the AWS C2S environment
Limitations in AWS GovCloud (US) regions
Cloud Manager must be deployed in an AWS GovCloud (US) region if you want to launch Cloud Volumes ONTAP instances in any AWS GovCloud (US) region.
When deployed in an AWS GovCloud (US) region, Cloud Manager cannot discover ONTAP clusters in a NetApp Private Storage for Microsoft Azure configuration or a NetApp Private Storage for SoftLayer configuration.
Detaching and reattaching EBS volumes is not supported
Detaching an EBS volume from a Cloud Volumes ONTAP instance and then reattaching it to another Cloud Volumes ONTAP instance is not supported. You should use Cloud Manager to replicate data between instances.
Known limitations in Microsoft Azure
The following known limitations affect Cloud Volumes ONTAP in Azure.
New deployments aren't supported
New deployments of Cloud Volumes ONTAP 9.5 are no longer supported in Azure. You'll need to deploy Cloud Volumes ONTAP 9.7.
HA limitations
The following limitations affect Cloud Volumes ONTAP HA pairs in Microsoft Azure:
Data tiering is not supported.
NFSv4 is not supported. NFSv3 is supported.
HA pairs are not supported in some regions.
