Cloud Volumes ONTAP release notes
What's new in Cloud Volumes ONTAP 9.19.1
Contributors netapp-manini netapp-rlithman netapp-bcammett netapp-driley netapp-sumathi netapp-dbagwell
You can now deploy and upgrade to Cloud Volumes ONTAP 9.19.1. You can see the base version of this release and the latest patch versions available for deployment and upgrade in the NetApp Console.
To know about more Cloud Volumes ONTAP features, supported configurations, limits, and more, see Cloud Volumes ONTAP documentation.
9.19.1 P4 (12 November 2026)
The Cloud Volumes ONTAP 9.19.1 P4 patch is now available for deployment and upgrade in Amazon Web Services (AWS), Microsoft Azure (Azure), and Google Cloud. The Console will prompt you to upgrade your existing systems to this patch release.
View the list of bugs fixed in the P4 patch (NetApp Support Site login required).
9.19.1 GA
The Cloud Volumes ONTAP 9.19.1 General Availability (GA) version is now available for deployment and upgrade in Amazon Web Services (AWS), Microsoft Azure (Azure), and Google Cloud.
Upgrade notes
Read through these notes to learn more about upgrading to this release.
How to upgrade
Upgrades of Cloud Volumes ONTAP must be completed from the Console. You should not upgrade Cloud Volumes ONTAP by using System Manager or the CLI. Doing so can impact system stability.
Supported upgrade path
You can upgrade to Cloud Volumes ONTAP 9.19.1 from 9.18.1 in AWS, Azure, and Google Cloud. The Console will prompt you to upgrade eligible Cloud Volumes ONTAP systems to this release.
Downtime
  • The upgrade of a single-node system takes the system offline for up to 25 minutes, during which I/O is interrupted.
  • Upgrading an HA pair is non-disruptive and I/O is uninterrupted. During this non-disruptive upgrade process, each node is upgraded in tandem to continue serving I/O to clients.
