Troubleshooting General Data Infrastructure Insights Problems
Here you will find suggestions for troubleshooting Data Infrastructure Insights.
Login issues
| Problem: | Try this: |
Data Infrastructure Insights automatically logs out every 6 hours |
This is due to disabled browser third-party cookies. Users can configure their browser to enable all 3rd party cookies, or use a narrower exception list to just enable those for Data Infrastructure Insights. |
I have a Console account but am unable to log in. |
Open a ticket from https://mysupport.netapp.com/site/help. Select category console.netapp.com > Account/Login issues” or console.netapp.com > Federation issues”. These are specifically for Console issues or questions. |
I got invited to Data Infrastructure Insights but I get a "not authorized" message. |
Verify that you have signed up for a Console account, or that your organization uses SSO login with Console. |
I logged out from Console and was automatically logged out from Data Infrastructure Insights. |
Single Sign-On (SSO) across NetApp Cloud Services logs out all Data Infrastructure Insights sessions. If you have access to multiple Data Infrastructure Insights accounts, logging out from any one logs out all active sessions. Log back in to access your account. |
I was automatically logged out after several days. |
NetApp Cloud accounts require reauthentication every few days (current Console setting is 7 days). Log back in to access your account. |
I receive an error message “no longer authorized to login”. |
Contact your account administrator to verify access to Data Infrastructure Insights. |
Other login errors |
Try incognito mode in Chrome, or clear browser history, cookies, and cache. |
Other Issues
Question: |
Answer: |
My Qtree hard quotas are showing correctly in queries, but my soft quotas are showing as the total capacity of the volume. Is that correct? |
Only hard quotas—either manually set or set through Trident—will show as the set quotas; if no hard quotas are specified, the Qtree capacity will be the internal volume capacity. |
I have both a soft and a hard quota manually set in the same Qtree, but the total capacity showing is the hard quota; is that correct? |
Yes, if a hard quota is specified, that will be shown as the total capacity. |
When entering a Cognos report schedule time, sometimes I end up with an extra "m" in the schedule time. For example, if I enter the time as "02:15 PM", it may add an extra character: "02:15 PMM" (or PMm). When I click outside, it changes it to "2:15 AM". |
Re-enter the schedule time, being careful not to enter the full "AM" or "PM" characters; it is enough to type "A" for "AM or "P" for "PM". If you are not shown the extra character, the schedule time will be set correctly. |
Resources
Additional troubleshooting tips may be found in the NetApp Knowledgebase (support sign-in required).
Additional support information may be found from the Data Infrastructure Insights Support page.
If you have an active Data Infrastructure Insights subscription you can use these support options:
For more information, see the Data Infrastructure Insights Support Documentation.
