NetApp Console and NetApp Console local deployment
Compare NetApp Console and NetApp Console local deployment
Contributors netapp-tonias netapp-ahibbard
NetApp offers two ways to run its unified storage management platform: NetApp Console and NetApp Console local deployment. Both share a common foundation, but they differ in architecture, connectivity, feature scope, and operational model. NetApp Console uses Console agents deployed in your environment to manage storage systems. NetApp Console local deployment is an agentless virtual machine. NetApp Console local deployment communicates directly with ONTAP clusters and delivers enterprise fleet management capabilities not available in NetApp Console.
Note Choose NetApp Console if you manage cloud and on-premises environments and want NetApp to handle platform infrastructure. Choose NetApp Console local deployment if you manage a large on-premises ONTAP estate and need full data sovereignty and policy-driven storage management.
NetApp Console
NetApp hosts and maintains NetApp Console as a SaaS application. You sign up and start managing storage immediately. To manage storage systems, you deploy lightweight Console agents in your cloud or on-premises environments. Agents connect outbound to the NetApp Console platform, and NetApp handles platform authentication, upgrades, and availability automatically.
NetApp Console also supports restricted mode (installed in your own public cloud with limited outbound connectivity) and private mode (installed on-premises or in your cloud with no connectivity to the NetApp Console platform, including air-gapped environments).
NetApp Console supports the broadest range of storage systems, including cloud storage such as Amazon FSx for ONTAP, Cloud Volumes ONTAP, Amazon S3, Google Cloud Storage, E-Series, StorageGRID, and on-premises ONTAP clusters. It provides access to the full suite of NetApp data services, including NetApp Backup and Recovery, NetApp Disaster Recovery, NetApp Ransomware Resilience, NetApp Copy and Sync, and NetApp Data Classification. NetApp Console also provides support contract features such as Digital Advisor, Lifecycle Planning, and Sustainability dashboards.
NetApp Console is best suited for organizations managing hybrid cloud environments that want the most features, less work to keep things running, and flexible licensing.
NetApp Console local deployment lets you run the NetApp Console control plane entirely within your own on-premises infrastructure, with no management traffic leaving your environment. You deploy the Console as a virtual machine using a virtual appliance image and manage it like any other virtual machine in your vCenter environment. No Console agents are required. The virtual machine communicates directly with your ONTAP clusters.
While NetApp Console private mode also supports air-gapped and on-premises deployments, Console local deployment is designed specifically for enterprise-scale ONTAP fleet management. It adds capabilities that are not available in any NetApp Console deployment mode:
Storage class policies
Define storage standards once as reusable templates that bundle performance, capacity, and tiering requirements. All provisioning uses approved classes, and Console local deployment continuously monitors workloads for compliance and identifies drift.
Fleet management
Organize clusters into folders and fleets that reflect your business structure, then delegate administration at organization, folder, or fleet scope.
Workload Analyzer
Correlate latency, throughput, input/output operations per second, and configuration changes over time to find performance issues before they affect workloads.
Large language model integration
Connect to your own large language model to provision storage using natural language, investigate alerts, and get contextual answers about your storage environment.
Guided and automated remediation
When a workload drifts from its storage class or an alert fires, Console local deployment provides Fix-It recommendations. Use guided steps or one-click automated remediation to restore compliance without manual steps.
Alert delivery via email and webhook
Configure email and webhook notification channels so that alerts reach the right teams when storage conditions change. Webhooks integrate with your existing monitoring and incident management tools.
Console local deployment supports on-premises ONTAP clusters and NetApp Backup and Recovery. It integrates with Active Directory for federated authentication and supports multi-factor authentication for local users.
Console local deployment is best suited for organizations with large on-premises ONTAP environments that require policy-driven provisioning, automated compliance checks, and full data sovereignty.
Feature comparison
Storage management
Feature NetApp Console NetApp Console local deployment
On-premises ONTAP clusters
Yes (requires Console agent)
Yes (direct communication from Console virtual machine)
Cloud storage systems (Amazon FSx for ONTAP, Cloud Volumes ONTAP, Amazon S3, and others)
Yes
No
E-Series and StorageGRID
Yes
No
Yes
Yes
Yes
No
Yes
No
Yes
No
Yes
No
Digital Advisor, Lifecycle Planning, Sustainability
Yes
No
Storage class policies and compliance monitoring
No
Yes
No
Yes
Fleet management (folders and fleets)
No
Yes
Workload Analyzer
No
Yes
Large language model integration for AI-assisted operations
No
Yes
Console setup and security
Deployment model
Software as a service, hosted by NetApp (different deployment modes available)
Self-hosted virtual machine in your own infrastructure
Console agent required
Yes
No
Software upgrades
Automatic, managed by NetApp
Manual
User interface access
NetApp Console application (internet or virtual machine access)
Console virtual machine (local, no internet required)
Data sovereignty
Management traffic goes to the NetApp Console platform
No data or management traffic leaves your environment
Active Directory integration
No
Yes
Identity federation
Yes
No
Multi-factor authentication (local users)
Yes
Yes
Audit logging
Yes
Yes
Licensing
Marketplace subscriptions and bring-your-own-license
Bring-your-own-license
