Learn about NetApp Console agent deployment methods
Deploy a Console agent using the NetApp Console, your cloud provider's marketplace, or by manually installing software on a Linux host. Your deployment method determines how you maintain the agent host and differs depending on which NetApp Console deployment mode you are using.
For cloud deployments, you can deploy an agent in Amazon Web Services (AWS), Microsoft Azure, or Google Cloud.
Deploy from the NetApp Console
NetApp recommends deploying from the NetApp Console when you use standard mode. The NetApp Console guides you through networking and permissions setup, then automatically launches the VM or instance in your cloud provider. The Console guides you through networking and permissions setup, then launches the VM or instance in your cloud provider automatically.
Choose this method when:
You are deploying in a standard cloud environment with outbound internet access.
You want the fastest path to a running agent with the least manual setup.
| Advantages | Disadvantages |
Deploy from a cloud provider marketplace
Deploying from the AWS Marketplace or Azure Marketplace initiates the agent installation directly from the marketplace, not from the NetApp Console.
A marketplace-equivalent option is available in Google Cloud using Google Cloud tools (gcloud CLI or Google Cloud console) rather than a traditional marketplace listing. |
Your organization requires all cloud software to be procured through the marketplace.
You prefer to initiate deployments from your cloud provider's interface rather than the NetApp Console.
Manually install on a Linux host in the cloud
Manual installation lets you install the Console agent software directly on a Linux host that you provide and manage in AWS, Azure, Google Cloud, or on-premises.
You need to deploy in a restricted mode or private mode environment without outbound internet access.
Your organization requires all software to be installed on pre-approved, internally managed hosts.
Manually install on-premises using vCenter (OVA)
If you use VMware vCenter, you can deploy the Console agent by importing an OVA (Open Virtual Appliance) file. The OVA is a pre-configured VM image you deploy with the vSphere client, without installing Linux or configuring a container runtime.
You are deploying on-premises in a VMware environment.
You want a simpler on-premises installation that requires less maintenance and Linux setup.
You cannot manage Google Cloud resources from an on-premises Console agent. To manage Google Cloud resources, install the agent in Google Cloud. |
Manually install on-premises (without vCenter)
You can manually install the Console agent on any on-premises Linux host. You must set up the Linux host and container runtime (Docker or Podman), then install the Console agent.
You are deploying on-premises and do not have a VMware vCenter environment.
You are comfortable with Linux administration and want to manage the underlying host yourself.
You want to control when the Console agent is upgraded.
