Manually install the NetApp Console agent in Azure
To manually install the Console agent on your own Linux host, you need to review host requirements, set up your networking, prepare Azure permissions, install the Console agent, and then provide the permissions that you prepared.
Deploying an agent in Azure launches a VM running Linux and the Console agent software in a VNet of your choice.
Deploy a Console agent in the same Azure region as the Cloud Volumes ONTAP systems it manages, or in the Azure region pair. This ensures that an Azure Private Link connection is used between Cloud Volumes ONTAP and its associated storage accounts. |
You should review Console agent limitations.
Step 1: Review host requirements
The Console agent software must run on a host that meets specific operating system requirements, RAM requirements, port requirements, and so on.
The Console agent reserves the UID and GID range of 19000 to 19200. This range is fixed and cannot be modified. If any third-party software on your host is using UIDs or GIDs within this range, the agent installation will fail. NetApp recommends using a host that is free of third-party software to avoid conflicts. |
- Dedicated host
The Console agent requires a dedicated host. Any architecture is supported if it meets these size requirements:
CPU: 8 cores or 8 vCPUs
RAM: 32 GB
Disk space: 165 GB is recommended for the host, with the following partition requirements:
/opt: 120 GiB of space must be availableThe agent uses
/optto install the/opt/application/netappdirectory and its contents. -
/var: 40 GiB of space must be availableThe Console agent requires this space in
/varbecause Podman or Docker is architected to create the containers within this directory. Specifically, they will create containers in the/var/lib/containers/storagedirectory and/var/lib/dockerfor Docker. External mounts or symlinks do not work for this space.
- Azure VM size
An instance type that meets CPU and RAM requirements. NetApp recommends Standard_D8s_v3.
- Hypervisor
A bare metal or hosted hypervisor that is certified to run a supported operating system is required.
- Operating system and container requirements
The Console agent is supported with the following operating systems when using the Console in standard mode or restricted mode. A container orchestration tool is required before you install the agent.
| Operating system | Supported OS versions | Supported agent versions | Required container tool | SELinux |
Red Hat Enterprise Linux |
9.6
4.0.0 or later with the Console in standard mode or restricted mode |
Podman version 5.4.0 with podman-compose 1.5.0. |
Supported in enforcing mode or permissive mode |
9.1 to 9.4
3.9.50 or later with the Console in standard mode or restricted mode |
Podman version 4.9.4 with podman-compose 1.5.0. |
8.6 to 8.10
Podman version 4.6.1 or 4.9.4 with podman-compose 1.0.6. |
Ubuntu |
24.04 LTS |
3.9.45 or later with the NetApp Console in standard mode or restricted mode |
Docker Engine 23.0.6 to 28.0.0. |
Not supported |
22.04 LTS |
3.9.50 or later |
Not supported |
Step 2: Install Podman or Docker Engine
Depending on your operating system, either Podman or Docker Engine is required before installing the agent.
Podman is required for Red Hat Enterprise Linux 8 and 9.
Docker Engine is required for Ubuntu.
Follow these steps to install and configure Podman:
Enable and start the podman.socket service
Install python3
Install the podman-compose package (varies by Red Hat version)
Add podman-compose to the PATH environment variable
If using Red Hat Enterprise Linux, verify that your Podman version is using Netavark Aardvark DNS instead of CNI
Adjust the aardvark-dns port (default: 53) after installing the agent to avoid DNS port conflicts. Follow the instructions to configure the port. |
Remove the podman-docker package if it's installed on the host.
dnf remove podman-docker rm /var/run/docker.sock -
Install Podman.
You can obtain Podman from official Red Hat Enterprise Linux repositories.
For Red Hat Enterprise Linux 9.6:
sudo dnf install podman-5:<version>Where <version> is the supported version of Podman that you're installing. View the supported Podman versions.
For Red Hat Enterprise Linux 9.1 to 9.4:
sudo dnf install podman-4:<version>Where <version> is the supported version of Podman that you're installing. View the supported Podman versions.
For Red Hat Enterprise Linux 8:
Enable and start the podman.socket service.
sudo systemctl enable --now podman.socket -
Install python3.
sudo dnf install python3 -
Install the EPEL repository package if it's not already available on your system.
This step is required because podman-compose is available from the Extra Packages for Enterprise Linux (EPEL) repository.
If using Red Hat Enterprise 9:
Install the EPEL repository package.
sudo dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm-
Install podman-compose package 1.5.0.
sudo dnf install podman-compose-1.5.0
If using Red Hat Enterprise Linux 8:
sudo dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-8.noarch.rpm -
Install podman-compose package 1.0.6.
sudo dnf install podman-compose-1.0.6Using the dnf installcommand meets the requirement for adding podman-compose to the PATH environment variable. The installation command adds podman-compose to /usr/bin, which is already included in thesecure_pathoption on the host. -
If using Red Hat Enterprise Linux 8, verify that your Podman version is using NetAvark with Aardvark DNS instead of CNI.
Check to see if your networkBackend is set to CNI by running the following command:
podman info | grep networkBackend -
If the networkBackend is set to
CNI, you'll need to change it tonetavark. -
Install
netavarkandaardvark-dnsusing the following command:dnf install aardvark-dns netavark -
Open the
/etc/containers/containers.conffile and modify the network_backend option to use "netavark" instead of "cni".If
/etc/containers/containers.confdoesn't exist, make the configuration changes to/usr/share/containers/containers.conf. -
Restart podman.
systemctl restart podman -
Confirm networkBackend is now changed to "netavark" using the following command:
If associating this agent with a Cloud Volumes ONTAP system, consider increasing the number of threads associated with the agent to improve performance. Learn about increasing the agent's container thread limit.
Follow the documentation from Docker to install Docker Engine.
View installation instructions from Docker
Follow the steps to install a supported Docker Engine version. Do not install the latest version, as it is unsupported by the Console.
Verify that Docker is enabled and running.
sudo systemctl enable docker && sudo systemctl start docker
Step 3: Set up networking
Ensure that the network location where you plan to install the Console agent supports the following requirements. Meeting these requirements enables the Console agent to manage resources and processes within your hybrid cloud environment.
- Azure region
If you use Cloud Volumes ONTAP, the Console agent should be deployed in the same Azure region as the Cloud Volumes ONTAP systems that it manages, or in the Azure region pair for the Cloud Volumes ONTAP systems. This requirement ensures that an Azure Private Link connection is used between Cloud Volumes ONTAP and its associated storage accounts.
- Connections to target networks
The Console agent requires a network connection to the location where you're planning to create and manage systems. For example, the network where you plan to create Cloud Volumes ONTAP systems or a storage system in your on-premises environment.
- Outbound internet access
The network location where you deploy the Console agent must have an outbound internet connection to contact specific endpoints.
- Endpoints contacted from computers when using the web-based NetApp Console
Computers that access the Console from a web browser must have the ability to contact several endpoints.
- Endpoints contacted from the Console agent
The Console agent requires outbound internet access to contact the following endpoints to manage resources and processes within your public cloud environment for day-to-day operations.
The endpoints listed below are all CNAME entries.
Endpoints Purpose -
https://management.azure.com
https://login.microsoftonline.com
https://blob.core.windows.net
https://core.windows.net
To manage resources in Azure public regions.
https://management.chinacloudapi.cn
https://login.chinacloudapi.cn
https://blob.core.chinacloudapi.cn
https://core.chinacloudapi.cn
To manage resources in Azure China regions.
https://mysupport.netapp.com
To obtain licensing information and to send AutoSupport messages to NetApp Support.
https://signin.b2c.netapp.com
To update NetApp Support Site (NSS) credentials or to add new NSS credentials to the NetApp Console.
https://support.netapp.com
To obtain licensing information and to send AutoSupport messages to NetApp Support as well as to receive software updates for Cloud Volumes ONTAP.
https://api.bluexp.netapp.com
https://netapp-cloud-account.auth0.com
https://netapp-cloud-account.us.auth0.com
https://console.netapp.com
https://components.console.bluexp.netapp.com
https://cdn.auth0.com
To provide features and services within the NetApp Console.
https://bluexpinfraprod.eastus2.data.azurecr.io
https://bluexpinfraprod.azurecr.io
To obtain images for Console agent deployment and upgrades.
- Proxy server
NetApp supports both explicit and transparent proxy configurations. If you are using a transparent proxy, you only need to provide the certificate for the proxy server. If you are using an explicit proxy, you'll also need the IP address and credentials.
IP address
Credentials
HTTPS certificate
- Ports
There's no incoming traffic to the Console agent, unless you initiate it or it is used as a proxy to send AutoSupport messages from Cloud Volumes ONTAP to NetApp Support.
HTTP (80) and HTTPS (443) provide access to the local UI, which you'll use in rare circumstances.
SSH (22) is only needed if you need to connect to the host for troubleshooting.
Inbound connections over port 3128 are required if you deploy Cloud Volumes ONTAP systems in a subnet where an outbound internet connection isn't available.
If Cloud Volumes ONTAP systems don't have an outbound internet connection to send AutoSupport messages, the Console automatically configures those systems to use a proxy server that's included with the Console agent. The only requirement is to ensure that the Console agent's security group allows inbound connections over port 3128. You'll need to open this port after you deploy the Console agent.
- Enable NTP
If you're planning to use NetApp Data Classification to scan your corporate data sources, you should enable a Network Time Protocol (NTP) service on both the Console agent and the NetApp Data Classification system so that the time is synchronized between the systems. Learn more about NetApp Data Classification.
Step 4: Set up Console agent deployment permissions
You need to provide Azure permissions to the Console agent by using one of the following options:
Option 1: Assign a custom role to the Azure VM using a system-assigned managed identity.
Option 2: Provide the Console agent with the credentials for an Azure service principal that has the required permissions.
Follow the steps to prepare permissions for the Console agent.
Note that you can create an Azure custom role using the Azure portal, Azure PowerShell, Azure CLI, or REST API. The following steps show how to create the role using the Azure CLI. If you would prefer to use a different method, refer to Azure documentation
If you're planning to manually install the software on your own host, enable a system-assigned managed identity on the VM so that you can provide the required Azure permissions through a custom role.
Copy the contents of the custom role permissions for the Console agent and save them in a JSON file.
Modify the JSON file by adding Azure subscription IDs to the assignable scope.
You should add the ID for each Azure subscription that you want to use with the NetApp Console.
Example
"AssignableScopes": [ "/subscriptions/d333af45-0d07-4154-943d-c25fbzzzzzzz", "/subscriptions/54b91999-b3e6-4599-908e-416e0zzzzzzz", "/subscriptions/398e471c-3b42-4ae7-9b59-ce5bbzzzzzzz" ] -
Use the JSON file to create a custom role in Azure.
The following steps describe how to create the role by using Bash in Azure Cloud Shell.
Start Azure Cloud Shell and choose the Bash environment.
Upload the JSON file.
Use the Azure CLI to create the custom role:
az role definition create --role-definition agent_Policy.json
Create and set up a service principal in Microsoft Entra ID and obtain the Azure credentials that the Console agent needs.
Ensure that you have permissions in Azure to create an Active Directory application and to assign the application to a role.
For details, refer to Microsoft Azure Documentation: Required permissions
From the Azure portal, open the Microsoft Entra ID service.
In the menu, select App registrations.
Select New registration.
Specify details about the application:
Name: Enter a name for the application.
Account type: Select an account type (any will work with the NetApp Console).
Redirect URI: You can leave this field blank.
Select Register.
You've created the AD application and service principal.
Create a custom role:
You should add the ID for each Azure subscription from which users will create Cloud Volumes ONTAP systems.
Example
az role definition create --role-definition agent_Policy.jsonYou should now have a custom role called Console Operator that you can assign to the Console agent virtual machine.
Assign the application to the role:
From the Azure portal, open the Subscriptions service.
Select the subscription.
Select Access control (IAM) > Add > Add role assignment.
In the Role tab, select the Console Operator role and select Next.
In the Members tab, complete the following steps:
Keep User, group, or service principal selected.
Select Select members.
Search for the name of the application.
Here's an example:
Select the application and select Select.
Select Next.
Select Review + assign.
The service principal now has the required Azure permissions to deploy the Console agent.
If you want to deploy Cloud Volumes ONTAP from multiple Azure subscriptions, then you must bind the service principal to each of those subscriptions. In the NetApp Console, you can select the subscription that you want to use when deploying Cloud Volumes ONTAP.
In the Microsoft Entra ID service, select App registrations and select the application.
Select API permissions > Add a permission.
Under Microsoft APIs, select Azure Service Management.
Select Access Azure Service Management as organization users and then select Add permissions.
Copy the Application (client) ID and the Directory (tenant) ID.
When you add the Azure account to the Console, you need to provide the application (client) ID and the directory (tenant) ID for the application. The Console uses the IDs to programmatically sign in.
Open the Microsoft Entra ID service.
Select App registrations and select your application.
Select Certificates & secrets > New client secret.
Provide a description of the secret and a duration.
Select Add.
Copy the value of the client secret.
Your service principal is now set up and you should have copied the application (client) ID, the directory (tenant) ID, and the value of the client secret. You need to enter this information in the Console when you add an Azure account.
Step 5: Install the Console agent
After the pre-requisites are complete, you can manually install the software on your own Linux host.
You should have the following:
Root privileges to install the Console agent.
Details about a proxy server, if a proxy is required for internet access from the Console agent.
You have the option to configure a proxy server after installation, but doing so requires restarting the Console agent.
A CA-signed certificate, if the proxy server uses HTTPS or if the proxy is an intercepting proxy.
You cannot set a certificate for a transparent proxy server when manually installing the Console agent. If you need to set a certificate for a transparent proxy server, you must use the Maintenance Console after installation. Learn more about the Agent Maintenance Console. |
A managed identity enabled on the VM in Azure so that you can provide the required Azure permissions through a custom role.
After installation, the Console agent automatically updates itself if a new version is available.
If the http_proxy or https_proxy system variables are set on the host, remove them:
unset http_proxy unset https_proxyIf you don't remove these system variables, the installation fails.
Download the Console agent software and then copy it to the Linux host. You can download it either from the NetApp Console or the NetApp Support site.
NetApp Console: Go to Agents > Management > Deploy agent > On-prem > Manual install.
Choose download the agent installer files or a URL to the files.
NetApp Support Site (needed if you don't already have access to the Console).
Download the "online" agent installer that's meant for use in your network or in the cloud. A separate "offline" installer is available for the Console agent, but it's only supported with private mode deployments. -
NetApp Support Site (needed if you don't already have access to the Console) NetApp Support Site.
Assign permissions to run the script.
chmod +x NetApp_Console_Agent_Cloud_<version>Where <version> is the version of the Console agent that you downloaded.
If installing in a Government Cloud environment, disable the configuration checks. Learn how to disable configuration checks for manual installations.
Run the installation script.
./NetApp_Console_Agent_Cloud_<version> --proxy <HTTP or HTTPS proxy server> --cacert <path and file name of a CA-signed certificate>You'll need to add proxy information if your network requires a proxy for internet access. You can add an explicit proxy during installation. The
--proxyand--cacertparameters are optional and you won't be prompted to add them. If you have an explicit proxy server, you will need to enter the parameters as shown.If you want to configure a transparent proxy, you can do so after you've installed. Learn about the agent maintenance console. Here is an example of configuring an explicit proxy server with a CA-signed certificate:
./NetApp_Console_Agent_Cloud_v4.0.0 --proxy https://user:password@10.0.0.30:8080/ --cacert /tmp/cacert/certificate.cer ./NetApp_Console_Agent_Cloud_v4.0.0 --proxy https://user:password@10.0.0.30:8080/ --cacert /tmp/cacert/certificate.cer--proxyconfigures the Console agent to use an HTTP or HTTPS proxy server using one of the following formats:-
http://address:port
http://user-name:password@address:port
http://domain-name%92user-name:password@address:port
https://address:port
https://user-name:password@address:port
https://domain-name%92user-name:password@address:port
Note the following:
The user can be a local user or domain user.
For a domain user, you must use the ASCII code for a \ as shown above.
The Console agent doesn't support user names or passwords that include the @ character.
If the password includes any of the following special characters, you must escape that special character by prepending it with a backslash: & or !
For example:
http://bxpproxyuser:netapp1\!@address:3128
If you used Podman, you'll need to adjust the aardvark-dns port.
SSH to the Console agent virtual machine.
Open podman /usr/share/containers/containers.conf file and modify the chosen port for Aardvark DNS service. For example, change it to 54.
vi /usr/share/containers/containers.confFor example:
# Port to use for dns forwarding daemon with netavark in rootful bridge # mode and dns enabled. # Using an alternate port might be useful if other DNS services should # run on the machine. # dns_bind_port = 54 -
Reboot the Console agent virtual machine.
Wait for the installation to complete.
At the end of the installation, the Console agent service (occm) restarts twice if you specified a proxy server.
If the installation fails, you can view the installation report and logs to help you fix the issues. Learn how to troubleshoot installation issues. -
Open a web browser from a host that has a connection to the Console agent virtual machine and enter the following URL:
https://ipaddress
After you log in, set up the Console agent:
Specify the organization to associate with the Console agent.
Enter a name for the system.
Under Are you running in a secured environment? keep restricted mode disabled.
You should keep restricted mode disabled because these steps describe how to use the Console in standard mode. You should enable restricted mode only if you have a secure environment and want to disconnect this account from backend services. If that's the case, follow steps to get started with the NetApp Console in restricted mode.
Select Let's start.
If you have Azure Blob storage in the same Azure subscription where you created the Console agent, you'll see an Azure Blob storage system appear on the Systems page automatically. Learn how to manage Azure Blob storage from NetApp Console
Step 6: Provide permissions to NetApp Console
Now that you've installed the Console agent, you need to provide the Console agent with the Azure permissions that you previously set up. Providing the permissions enables the Console to manage your data and storage infrastructure in Azure.
Go to the Azure portal and assign the Azure custom role to the Console agent virtual machine for one or more subscriptions.
From the Azure Portal, open the Subscriptions service and select your subscription.
It's important to assign the role from the Subscriptions service because this specifies the scope of the role assignment at the subscription level. The scope defines the set of resources that the access applies to. If you specify a scope at a different level (for example, at the virtual machine level), your ability to complete actions from within the NetApp Console will be affected.
Console Operator is the default name provided in the policy. If you chose a different name for the role, then select that name instead. -
Assign access to a Managed identity.
Select Select members, select the subscription in which the Console agent virtual machine was created, under Managed identity, choose Virtual machine, and then select the Console agent virtual machine.
Select Select.
Select Next.
If you want to manage resources in additional Azure subscriptions, switch to that subscription and then repeat these steps.
Go to the NetApp Console to start using the Console agent.
Select Administration > Credentials.
Select Add Credentials and follow the steps in the wizard.
Credentials Location: Select Microsoft Azure > Agent.
Define Credentials: Enter information about the Microsoft Entra service principal that grants the required permissions:
Client Secret
Marketplace Subscription: Associate a Marketplace subscription with these credentials by subscribing now or by selecting an existing subscription.
Review: Confirm the details about the new credentials and select Add.
The Console agent now has the permissions that it needs to perform actions in Azure on your behalf.
