Manually deploy a Console agent in AWS for NetApp Console
You can manually deploy a Console agent on a Linux host running in AWS. To manually deploy the Console agent on your own Linux host, you need to review host requirements, set up your networking, prepare AWS permissions, deploy the Console agent, and then provide the permissions that you prepared.
Deploying an agent in AWS launches an EC2 instance running Linux and the Console agent software in a VPC of your choice.
You should review Console agent limitations.
Step 1: Review host requirements
Ensure the host running the Console agent software meets operating system, RAM, and port requirements.
The Console agent reserves the UID and GID range of 19000 to 19200. This range is fixed and cannot be modified. If any third-party software on your host is using UIDs or GIDs within this range, the agent installation will fail. NetApp recommends using a host that is free of third-party software to avoid conflicts. |
- Dedicated host
The Console agent requires a dedicated host. Any architecture is supported if it meets these size requirements:
CPU: 8 cores or 8 vCPUs
RAM: 32 GB
Disk space: 165 GB is recommended for the host, with the following partition requirements:
/opt: 120 GiB of space must be availableThe agent uses
/optto install the/opt/application/netappdirectory and its contents. -
/var: 40 GiB of space must be availableThe Console agent requires this space in
/varbecause Podman or Docker is architected to create the containers within this directory. Specifically, they will create containers in the/var/lib/containers/storagedirectory and/var/lib/dockerfor Docker. External mounts or symlinks do not work for this space.
- AWS EC2 instance type
An instance type that meets CPU and RAM requirements. NetApp recommends t3.2xlarge.
- Hypervisor
A bare metal or hosted hypervisor that is certified to run a supported operating system is required.
- Operating system and container requirements
The Console agent is supported with the following operating systems when using the Console in standard mode or restricted mode. A container orchestration tool is required before you install the agent.
| Operating system | Supported OS versions | Supported agent versions | Required container tool | SELinux |
Red Hat Enterprise Linux |
9.6
4.0.0 or later with the Console in standard mode or restricted mode |
Podman version 5.4.0 with podman-compose 1.5.0. |
Supported in enforcing mode or permissive mode |
9.1 to 9.4
3.9.50 or later with the Console in standard mode or restricted mode |
Podman version 4.9.4 with podman-compose 1.5.0. |
8.6 to 8.10
Podman version 4.6.1 or 4.9.4 with podman-compose 1.0.6. |
Ubuntu |
24.04 LTS |
3.9.45 or later with the NetApp Console in standard mode or restricted mode |
Docker Engine 23.0.6 to 28.0.0. |
Not supported |
22.04 LTS |
3.9.50 or later |
Not supported |
- Key pair
When you create the Console agent, you'll need to select an EC2 key pair to use with the instance.
- PUT response hop limit when using IMDSv2
If IMDSv2 is enabled (the default for new EC2 instances), set the PUT response hop limit to 3. If you do not, the system displays a UI initialization error during agent setup.
Step 2: Install Podman or Docker Engine
Depending on your operating system, either Podman or Docker Engine is required before installing the agent.
Podman is required for Red Hat Enterprise Linux 8 and 9.
Docker Engine is required for Ubuntu.
Follow these steps to install and configure Podman:
Enable and start the podman.socket service
Install python3
Install the podman-compose package (varies by Red Hat version)
Add podman-compose to the PATH environment variable
If using Red Hat Enterprise Linux, verify that your Podman version is using Netavark Aardvark DNS instead of CNI
Adjust the aardvark-dns port (default: 53) after installing the agent to avoid DNS port conflicts. Follow the instructions to configure the port. |
Remove the podman-docker package if it's installed on the host.
dnf remove podman-docker rm /var/run/docker.sock -
Install Podman.
You can obtain Podman from official Red Hat Enterprise Linux repositories.
For Red Hat Enterprise Linux 9.6:
sudo dnf install podman-5:<version>Where <version> is the supported version of Podman that you're installing. View the supported Podman versions.
For Red Hat Enterprise Linux 9.1 to 9.4:
sudo dnf install podman-4:<version>Where <version> is the supported version of Podman that you're installing. View the supported Podman versions.
For Red Hat Enterprise Linux 8:
Enable and start the podman.socket service.
sudo systemctl enable --now podman.socket -
Install python3.
sudo dnf install python3 -
Install the EPEL repository package if it's not already available on your system.
This step is required because podman-compose is available from the Extra Packages for Enterprise Linux (EPEL) repository.
If using Red Hat Enterprise 9:
Install the EPEL repository package.
sudo dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm-
Install podman-compose package 1.5.0.
sudo dnf install podman-compose-1.5.0
If using Red Hat Enterprise Linux 8:
sudo dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-8.noarch.rpm -
Install podman-compose package 1.0.6.
sudo dnf install podman-compose-1.0.6Using the dnf installcommand meets the requirement for adding podman-compose to the PATH environment variable. The installation command adds podman-compose to /usr/bin, which is already included in thesecure_pathoption on the host. -
If using Red Hat Enterprise Linux 8, verify that your Podman version is using NetAvark with Aardvark DNS instead of CNI.
Check to see if your networkBackend is set to CNI by running the following command:
podman info | grep networkBackend -
If the networkBackend is set to
CNI, you'll need to change it tonetavark. -
Install
netavarkandaardvark-dnsusing the following command:dnf install aardvark-dns netavark -
Open the
/etc/containers/containers.conffile and modify the network_backend option to use "netavark" instead of "cni".If
/etc/containers/containers.confdoesn't exist, make the configuration changes to/usr/share/containers/containers.conf. -
Restart podman.
systemctl restart podman -
Confirm networkBackend is now changed to "netavark" using the following command:
If associating this agent with a Cloud Volumes ONTAP system, consider increasing the number of threads associated with the agent to improve performance. Learn about increasing the agent's container thread limit.
Follow the documentation from Docker to install Docker Engine.
View installation instructions from Docker
Follow the steps to install a supported Docker Engine version. Do not install the latest version, as it is unsupported by the Console.
Verify that Docker is enabled and running.
sudo systemctl enable docker && sudo systemctl start docker
Step 3: Set up networking
Ensure the network location supports the following requirements so the Console agent can manage resources in your hybrid cloud.
- Connections to target networks
The Console agent requires a network connection to the location where you're planning to create and manage systems. For example, the network where you plan to create Cloud Volumes ONTAP systems or a storage system in your on-premises environment.
- Outbound internet access
The network location where you deploy the Console agent must have an outbound internet connection to contact specific endpoints.
- Endpoints contacted from computers when using the web-based NetApp Console
Computers that access the Console from a web browser must have the ability to contact several endpoints.
- Endpoints contacted from the Console agent
The Console agent requires outbound internet access to contact the following endpoints to manage resources and processes within your public cloud environment for day-to-day operations.
The endpoints listed below are all CNAME entries.
Endpoints Purpose AWS services (amazonaws.com):
CloudFormation
Elastic Compute Cloud (EC2)
Identity and Access Management (IAM)
Key Management Service (KMS)
Security Token Service (STS)
Simple Storage Service (S3)
To manage AWS resources. The endpoint depends on your AWS region. Refer to AWS documentation for details
Amazon FSx for NetApp ONTAP:
api.workloads.netapp.com
The web-based console contacts this endpoint to interact with the Workload Factory APIs to manage and operate FSx for ONTAP-based workloads.
https://mysupport.netapp.com
To obtain licensing information and to send AutoSupport messages to NetApp Support.
https://signin.b2c.netapp.com
To update NetApp Support Site (NSS) credentials or to add new NSS credentials to the NetApp Console.
https://support.netapp.com
To obtain licensing information and to send AutoSupport messages to NetApp Support as well as to receive software updates for Cloud Volumes ONTAP.
https://api.bluexp.netapp.com
https://netapp-cloud-account.auth0.com
https://netapp-cloud-account.us.auth0.com
https://console.netapp.com
https://components.console.bluexp.netapp.com
https://cdn.auth0.com
To provide features and services within the NetApp Console.
https://bluexpinfraprod.eastus2.data.azurecr.io
https://bluexpinfraprod.azurecr.io
To obtain images for Console agent deployment and upgrades.
- Proxy server
NetApp supports both explicit and transparent proxy configurations. If you are using a transparent proxy, you only need to provide the certificate for the proxy server. If you are using an explicit proxy, you'll also need the IP address and credentials.
IP address
Credentials
HTTPS certificate
- Ports
There's no incoming traffic to the Console agent, unless you initiate it or it is used as a proxy to send AutoSupport messages from Cloud Volumes ONTAP to NetApp Support.
HTTP (80) and HTTPS (443) provide access to the local UI, which you'll use in rare circumstances.
SSH (22) is only needed if you need to connect to the host for troubleshooting.
Inbound connections over port 3128 are required if you deploy Cloud Volumes ONTAP systems in a subnet where an outbound internet connection isn't available.
If Cloud Volumes ONTAP systems don't have an outbound internet connection to send AutoSupport messages, the Console automatically configures those systems to use a proxy server that's included with the Console agent. The only requirement is to ensure that the Console agent's security group allows inbound connections over port 3128. You'll need to open this port after you deploy the Console agent.
- Enable NTP
If you're planning to use NetApp Data Classification to scan your corporate data sources, you should enable a Network Time Protocol (NTP) service on both the Console agent and the NetApp Data Classification system so that the time is synchronized between the systems. Learn more about NetApp Data Classification.
Step 4: Set up AWS permissions for the Console
Provide AWS permissions to the NetApp Console using one of these options:
Option 1: Create IAM policies and attach the policies to an IAM role that you can associate with the EC2 instance.
Option 2: Provide the Console with the AWS access key for an IAM user who has the required permissions.
Follow the steps to prepare permissions for the Console.
Log in to the AWS console and navigate to the IAM service.
Create a policy:
Select Policies > Create policy.
Select JSON and copy and paste the contents of the IAM policy for the Console agent.
Finish the remaining steps to create the policy.
Depending on the NetApp data services you plan to use, you might need to create a second policy. For standard regions, the permissions are spread across two policies. Two policies are required due to a maximum character size limit for managed policies in AWS. Learn more about IAM policies for the Console agent.
Create an IAM role:
Select Roles > Create role.
Select AWS service > EC2.
Add permissions by attaching the policy that you just created.
Finish the remaining steps to create the role.
You now have an IAM role that you can associate with the EC2 instance after you install the Console agent.
Create a policy:
Depending on the NetApp data services that you plan to use, you might need to create a second policy.
Attach the policies to an IAM user.
Ensure that the user has an access key that you can add to the NetApp Console after you install the Console agent.
You now have an IAM user that has the required permissions and an access key that you can provide to the Console.
Step 5: Install the Console agent
After you complete the prerequisites, manually install the software on your Linux host.
You should have the following:
Root privileges to install the Console agent.
Details about a proxy server, if a proxy is required for internet access from the Console agent.
You have the option to configure a proxy server after installation, but doing so requires restarting the Console agent.
A CA-signed certificate, if the proxy server uses HTTPS or if the proxy is an intercepting proxy.
You cannot set a certificate for a transparent proxy server when manually installing the Console agent. If you need to set a certificate for a transparent proxy server, you must use the Maintenance Console after installation. Learn more about the Agent Maintenance Console. |
After installation, the Console agent automatically updates itself if a new version is available.
If the http_proxy or https_proxy system variables are set on the host, remove them:
unset http_proxy unset https_proxyIf you don't remove these system variables, the installation fails.
Download the Console agent software and then copy it to the Linux host. You can download it either from the NetApp Console or the NetApp Support site.
NetApp Console: Go to Agents > Management > Deploy agent > On-prem > Manual install.
Choose download the agent installer files or a URL to the files.
NetApp Support Site (needed if you don't already have access to the Console).
Download the "online" agent installer that's meant for use in your network or in the cloud. A separate "offline" installer is available for the Console agent, but it's only supported with private mode deployments. -
NetApp Support Site (needed if you don't already have access to the Console) NetApp Support Site.
Assign permissions to run the script.
chmod +x NetApp_Console_Agent_Cloud_<version>Where <version> is the version of the Console agent that you downloaded.
If installing in a Government Cloud environment, disable the configuration checks. Learn how to disable configuration checks for manual installations.
Run the installation script.
./NetApp_Console_Agent_Cloud_<version> --proxy <HTTP or HTTPS proxy server> --cacert <path and file name of a CA-signed certificate>You'll need to add proxy information if your network requires a proxy for internet access. You can add an explicit proxy during installation. The
--proxyand--cacertparameters are optional and you won't be prompted to add them. If you have an explicit proxy server, you will need to enter the parameters as shown.If you want to configure a transparent proxy, you can do so after you've installed. Learn about the agent maintenance console. Here is an example of configuring an explicit proxy server with a CA-signed certificate:
./NetApp_Console_Agent_Cloud_v4.0.0 --proxy https://user:password@10.0.0.30:8080/ --cacert /tmp/cacert/certificate.cer ./NetApp_Console_Agent_Cloud_v4.0.0 --proxy https://user:password@10.0.0.30:8080/ --cacert /tmp/cacert/certificate.cer--proxyconfigures the Console agent to use an HTTP or HTTPS proxy server using one of the following formats:-
http://address:port
http://user-name:password@address:port
http://domain-name%92user-name:password@address:port
https://address:port
https://user-name:password@address:port
https://domain-name%92user-name:password@address:port
Note the following:
The user can be a local user or domain user.
For a domain user, you must use the ASCII code for a \ as shown above.
The Console agent doesn't support user names or passwords that include the @ character.
If the password includes any of the following special characters, you must escape that special character by prepending it with a backslash: & or !
For example:
http://bxpproxyuser:netapp1\!@address:3128
If you used Podman, you'll need to adjust the aardvark-dns port.
SSH to the Console agent virtual machine.
Open podman /usr/share/containers/containers.conf file and modify the chosen port for Aardvark DNS service. For example, change it to 54.
vi /usr/share/containers/containers.confFor example:
# Port to use for dns forwarding daemon with netavark in rootful bridge # mode and dns enabled. # Using an alternate port might be useful if other DNS services should # run on the machine. # dns_bind_port = 54 -
Reboot the Console agent virtual machine.
Wait for the installation to complete.
At the end of the installation, the Console agent service (occm) restarts twice if you specified a proxy server.
If the installation fails, you can view the installation report and logs to help you fix the issues. Learn how to troubleshoot installation issues. -
Open a web browser from a host that has a connection to the Console agent virtual machine and enter the following URL:
https://ipaddress
After you log in, set up the Console agent:
Specify the organization to associate with the Console agent.
Enter a name for the system.
Under Are you running in a secured environment? keep restricted mode disabled.
You should keep restricted mode disabled because these steps describe how to use the Console in standard mode. You should enable restricted mode only if you have a secure environment and want to disconnect this account from backend services. If that's the case, follow steps to get started with the NetApp Console in restricted mode.
Select Let's start.
If you have Amazon S3 buckets in the same AWS account where you created the Console agent, you'll see an Amazon S3 storage system appear on the Systems page automatically. Learn how to manage S3 buckets from NetApp Console
Step 6: Provide permissions to NetApp Console
After you install the Console agent, provide the AWS permissions you set up so the Console agent can manage your data and storage infrastructure in AWS.
Attach the IAM role you create to the Console agent EC2 instance.
Go to the Amazon EC2 console.
Select Instances.
Select the Console agent instance.
Select Actions > Security > Modify IAM role.
Select the IAM role and select Update IAM role.
Go to the NetApp Console to start using the Console agent.
Provide the Console with the AWS access key for an IAM user that has the required permissions.
Ensure that the correct Console agent is currently selected in the Console.
Select Administration > Credentials.
Select Organization credentials.
Select Add Credentials and follow the steps in the wizard.
Credentials Location: Select Amazon Web Services > Agent.
Define Credentials: Enter an AWS access key and secret key.
Marketplace Subscription: Associate a Marketplace subscription with these credentials by subscribing now or by selecting an existing subscription.
Review: Confirm the details about the new credentials and select Add.
