NetApp Console setup and administration
Enable read-only mode for a NetApp Console organization
Contributors netapp-tonias
As a security precaution, you can enable read-only mode for your NetApp Console organization. In read-only mode, users can view resources and settings but cannot make any changes.
In read-only mode, users with admin roles must manually elevate their permissions to make changes, which ensures that changes are intentional.
Note Read-only mode is not available when NetApp Console is in private mode. Learn more about NetApp Console modes.
Required access roles
Super admin or Org admin.
Enable read-only mode for your Console organization
Enable read-only mode to restrict changes to your Console organization. All users can still view resources. Users with admin roles cannot perform any actions in the Console without manually elevating their permissions.
When read-only mode is enabled, users see a banner that notifies them that the organization is in read-only mode. Users must go to User settings to elevate their role.
Steps
  1. Select Administration > Identity and access.
  2. From the Organizations tab, select Edit organization settings for the organization that you want to set to read-only mode.
  3. In the Read-only mode section, enable read-only mode by moving the toggle to the On position and then select Save.
    A screenshot that shows the Read-only mode toggle in the On position.
