NetApp Copy and Sync
Quick start for NetApp Copy and Sync
Contributors netapp-ahibbard amgrissino
Getting started with NetApp Copy and Sync includes a few steps.
One Log in and set up the NetApp Console
You should have gotten started with the NetApp Console, which includes logging in, setting up an account, and possibly deploying a Console agent and creating systems.
If you want to create sync relationships for any of the following, then you first need to create or discover a system:
  • Amazon FSx for ONTAP
  • Azure NetApp Files
  • Cloud Volumes ONTAP
  • On-prem ONTAP clusters
A Console agent is required for Cloud Volumes ONTAP, on-prem ONTAP clusters, and Amazon FSx for ONTAP.
Two Prepare your source and target
Verify that your source and target are supported and set up. The most important requirement is to verify connectivity between the data broker group and the source and target locations.
Three Prepare a location for the NetApp data broker
The NetApp data broker software syncs data from a source to a target (this is called a sync relationship). You can run the data broker in AWS, Azure, Google Cloud Platform, or on your premises. A data broker group, which consists of one or more data brokers, needs an outbound internet connection over port 443 so it can communicate with NetApp Copy and Sync and contact a few other services and repositories. View the list of endpoints.
NetApp Copy and Sync guides you through the installation process when you create a sync relationship, at which point you can deploy a data broker in the cloud or download an install script for your own Linux host.
Four Create your first sync relationship
Log in to the NetApp Console, select Sync, and then drag and drop your selections for the source and target. Follow the prompts to complete the setup. Learn more.
Five Pay for your sync relationships after your free trial ends
Subscribe from AWS or Azure to pay-as-you-go or to pay annually. Or purchase licenses directly from NetApp. Just go to the License Settings page in NetApp Copy and Sync to set it up. Learn more.
