Back up on-premises ONTAP data to StorageGRID with NetApp Backup and Recovery
Contributors guillermotome
In NetApp Backup and Recovery, you can back up volume data from your primary on-premises ONTAP systems to a secondary storage system and to StorageGRID object storage. Use this page to prepare your environment and activate backups.
Note "On-premises ONTAP systems" include FAS, AFF, and ONTAP Select systems.
Note To switch to and from NetApp Backup and Recovery workloads, refer to Switch to different NetApp Backup and Recovery workloads.
Identify the connection method
The following image shows each component when backing up an on-premises ONTAP system to StorageGRID and the connections that you need to prepare between them.
Optionally, you can connect to a secondary ONTAP system in the same on-premises location to replicate volumes.
A diagram showing how NetApp Backup and Recovery communicates with the volumes on the source systems and the destination storage where the backup files are located.
When the Console agent and on-premises ONTAP system are installed in an on-premises location without internet access (a "dark site"), the StorageGRID system must be located in the same on-premises data center. Archival of older backup files to public cloud is not supported in dark site configurations.
Prepare your Console agent
The Console agent is the main software for NetApp Console functionality. A Console agent is required to back up and restore your ONTAP data.
Create or switch Console agents
When you back up data to StorageGRID, a Console agent must be available on your premises. You'll either need to install a new Console agent or make sure that the currently selected Console agent resides on-premises. The Console agent can be installed in a site with or without internet access.
Prepare Console agent networking requirements
Ensure that the network where the Console agent is installed enables the following connections:
  • An HTTPS connection over port 443 to the StorageGRID Gateway Node
  • An HTTPS connection over port 443 to your ONTAP cluster management LIF
  • An outbound internet connection over port 443 to NetApp Backup and Recovery (not required when the Console agent is installed in a "dark" site)
Private mode (dark site) considerations
  • NetApp Backup and Recovery functionality is built into the Console agent. When it is installed in private mode, you'll need to update the Console agent software periodically to get access to new features. Check the NetApp Backup and Recovery What's New to see the new features in each NetApp Backup and Recovery release. When you want to use the new features, follow the steps to upgrade the Console agent software.
    The new version of NetApp Backup and Recovery that includes the ability to schedule and create snapshots and replicated volumes, in addition to creating backups to object storage, requires that you are using version 3.9.31 or greater of the Console agent. NetApp recommends that you use this latest release to manage all your backups.
  • When you use NetApp Backup and Recovery in a SaaS environment, the NetApp Backup and Recovery configuration data is backed up to the cloud. When you use NetApp Backup and Recovery in a site with no internet access, the NetApp Backup and Recovery configuration data is backed up to the StorageGRID bucket where your backups are being stored.
Verify license requirements
Before you can activate NetApp Backup and Recovery for your cluster, you'll need to purchase and activate a NetApp Backup and Recovery BYOL license from NetApp. This license is for the account and can be used across multiple systems.
You'll need the serial number from NetApp that enables you to use the service for the duration and capacity of the license. Learn how to manage your BYOL licenses.
Tip PAYGO licensing is not supported when backing up files to StorageGRID.
Prepare your ONTAP clusters
Prepare your source on-premises ONTAP system and any secondary on-premises ONTAP or Cloud Volumes ONTAP systems.
Preparing your ONTAP clusters involves the following steps:
  • Discover your ONTAP systems in NetApp Console
  • Verify ONTAP system requirements
  • Verify ONTAP networking requirements for backing up data to object storage
  • Verify ONTAP networking requirements for replicating volumes
Both your source on-premises ONTAP system and any secondary on-premises ONTAP or Cloud Volumes ONTAP systems must be available on the NetApp Console Systems page.
You'll need to know the cluster management IP address and the password for the admin user account to add the cluster.
Learn how to discover a cluster.
Make sure your ONTAP system meets the following requirements:
You must configure the following requirements on the system that connects to object storage.
  • When you use a fan-out backup architecture, the following settings must be configured on the primary storage system.
  • When you use a cascaded backup architecture, the following settings must be configured on the secondary storage system.
The following ONTAP cluster networking requirements are needed:
  • The ONTAP cluster initiates an HTTPS connection over a user-specified port from the intercluster LIF to the StorageGRID Gateway Node for backup and restore operations. The port is configurable during backup setup.
    ONTAP reads and writes data to and from object storage. The object storage never initiates, it just responds.
  • ONTAP requires an inbound connection from the Console agent to the cluster management LIF. The Console agent must reside on your premises.
  • An intercluster LIF is required on each ONTAP node that hosts the volumes you want to back up. The LIF must be associated with the IPspace that ONTAP should use to connect to object storage. Learn more about IPspaces.
    When you set up NetApp Backup and Recovery, you are prompted for the IPspace to use. You should choose the IPspace that each LIF is associated with. That might be the "Default" IPspace or a custom IPspace that you created.
  • The nodes' intercluster LIFs are able to access the object store (not required when the Console agent is installed in a "dark" site).
  • DNS servers have been configured for the storage VM where the volumes are located. See how to configure DNS services for the SVM.
  • If you are using a different IPspace than the Default, then you might need to create a static route to get access to the object storage.
  • Update firewall rules, if necessary, to allow NetApp Backup and Recovery service connections from ONTAP to object storage through the port you specified (typically port 443) and name resolution traffic from the storage VM to the DNS server over port 53 (TCP/UDP).
If you plan to create replicated volumes on a secondary ONTAP system using NetApp Backup and Recovery, make sure that the source and destination systems meet the following networking requirements.
On-premises ONTAP networking requirements
  • If the cluster is on-premises, you should have a connection from your corporate network to your virtual network in the cloud provider. This is typically a VPN connection.
  • ONTAP clusters must meet additional subnet, port, firewall, and cluster requirements.
    Because you can replicate to Cloud Volumes ONTAP or an on-premises systems, review peering requirements for on-premises ONTAP systems. View prerequisites for cluster peering in the ONTAP documentation.
Cloud Volumes ONTAP networking requirements
  • The instance's security group must include the required inbound and outbound rules: specifically, rules for ICMP and ports 11104 and 11105. These rules are included in the predefined security group.
Prepare StorageGRID as your backup target
StorageGRID must meet the following requirements. See the StorageGRID documentation for more information.
For details about DataLock and Ransomware protection requirements for StorageGRID, refer to Backup-to-object policy options.
Supported StorageGRID versions
StorageGRID 10.3 and later is supported.
To use DataLock & Ransomware protection for your backups, your StorageGRID systems must be running version 11.6.0.3 or greater.
To tier older backups to cloud archival storage, your StorageGRID systems must be running version 11.3 or greater. Additionally, your StorageGRID systems must be discovered to the Console Systems page.
To use archival storage, admin node IP access is needed.
Gateway IP access is always needed.
S3 credentials
You must have created an S3 tenant account to control access to your StorageGRID storage. See the StorageGRID docs for details.
When you set up backup to StorageGRID, the backup wizard prompts you for an S3 access key and secret key for a tenant account. The tenant account enables NetApp Backup and Recovery to authenticate and access the StorageGRID buckets used to store backups. The keys are required so that StorageGRID knows who is making the request.
These access keys must be associated with a user who has the following permissions:
"s3:ListAllMyBuckets",
"s3:ListBucket",
"s3:GetObject",
"s3:PutObject",
"s3:DeleteObject",
"s3:CreateBucket"
Object versioning
You must not enable StorageGRID object versioning manually on the object store bucket.
Prepare to archive older backup files to public cloud storage
Tiering older backup files to archival storage saves money by using a less expensive storage class for backups that you may not need. StorageGRID is an on-premises (private cloud) solution that doesn't provide archival storage, but you can move older backup files to public cloud archival storage. When used in this fashion, data that is tiered to cloud storage, or restored from cloud storage, goes between StorageGRID and the cloud storage - the Console is not involved in this data transfer.
Current support enables you to archive backups to AWS S3 Glacier/S3 Glacier Deep Archive or Azure Archive storage.
ONTAP Requirements
  • Your cluster must be using ONTAP 9.12.1 or greater.
StorageGRID Requirements
Amazon S3 requirements
  • You'll need to sign up for an Amazon S3 account for the storage space where your archived backups will be located.
  • You can choose to tier backups to AWS S3 Glacier or S3 Glacier Deep Archive storage. Learn more about AWS archival tiers.
  • StorageGRID should have full-control access to the bucket (s3:*); however, if this is not possible, the bucket policy must grant the following S3 permissions to StorageGRID:
    • s3:AbortMultipartUpload
    • s3:DeleteObject
    • s3:GetObject
    • s3:ListBucket
    • s3:ListBucketMultipartUploads
    • s3:ListMultipartUploadParts
    • s3:PutObject
    • s3:RestoreObject
Azure Blob requirements
  • You'll need to sign up for an Azure Subscription for the storage space where your archived backups will be located.
  • The activation wizard enables you to use an existing Resource Group to manage the Blob container that will store the backups, or you can create a new Resource Group.
When defining the Archival settings for the backup policy for your cluster, you'll enter your cloud provider credentials and select the storage class that you want to use. NetApp Backup and Recovery creates the cloud bucket when you activate backup for the cluster. The information required for AWS and Azure archival storage is shown below.
A screenshot of the information you'll need to archive backup files from StorageGRID to AWS S3 or Azure Blob.
The archival policy settings you select will generate an information lifecycle management (ILM) policy in StorageGRID, and add the settings as "rules."
  • If there is an existing active ILM policy, new rules will be added to the ILM policy to move the data to the archive tier.
  • If there is an existing ILM policy in the "proposed" state, the creation and activation of a new ILM policy will not be possible. Learn more about StorageGRID ILM policies and rules.
Activate backups on your ONTAP volumes
Activate backups at any time directly from your on-premises system.
A wizard takes you through the following major steps:
You can also Show the API commands at the review step, so you can copy the code to automate backup activation for future systems.
Start the wizard
Steps
  1. Access the Activate Backup and Recovery wizard using one of the following ways:
    • From the Console Systems page, select the system and select Enable > Backup Volumes next to Backup and Recovery in the right panel.
      If the destination for your backups exists as a system on the Console Systems page, you can drag the ONTAP cluster onto the object storage.
    • Select Volumes in the Backup and recovery bar. From the Volumes tab, select the Actions (…​) option and select Activate Backup for a single volume (that does not already have replication or backup to object storage already enabled).
    The Introduction page of the wizard shows the protection options including local snapshots, replication, and backups. If you did the second option in this step, the Define Backup Strategy page appears with one volume selected.
  2. Continue with the following options:
    • If you already have a Console agent, you're all set. Just select Next.
    • If you don't already have a Console agent, the Add a Console agent option appears. Refer to Prepare your Console agent.
Select the volumes that you want to back up
Choose the volumes you want to protect. A protected volume is one that has one or more of the following: snapshot policy, replication policy, backup to object policy.
You can choose to protect FlexVol or FlexGroup volumes; however, you cannot select a mix of these volumes when activating backup for a system. See how to activate backup for additional volumes in the system (FlexVol or FlexGroup) after you have configured backup for the initial volumes.
Note
  • You can activate a backup only on a single FlexGroup volume at a time.
  • When selecting source volumes that you want to protect, you can only select volumes that have matching SnapLock settings. The volumes you select must either all have the SnapLock feature enabled or all have the SnapLock feature disabled.
Steps
If the volumes you choose already have snapshot or replication policies applied, then the policies you select later will overwrite these existing policies.
  1. In the Select Volumes page, select the volume or volumes you want to protect.
    • Optionally, filter the rows to show only volumes with certain volume types, styles, and more to make the selection easier.
    • After you select the first volume, then you can select all FlexVol volumes (FlexGroup volumes can be selected one at a time only). To back up all existing FlexVol volumes, check one volume first and then check the box in the title row.
    • To back up individual volumes, check the box for each volume.
  2. Select Next.
Define the backup strategy
Defining the backup strategy involves setting the following options:
  • Whether you want one or all of the backup options: local snapshots, replication, and backup to object storage
  • Architecture
  • Local snapshot policy
  • Replication target and policy
    Note If the volumes you choose have different snapshot and replication policies than the policies you select in this step, the existing policies will be overwritten.
  • Backup to object storage information (provider, encryption, networking, backup policy, and export options).
Steps
  1. In the Define backup strategy page, choose one or all of the following. All three are selected by default:
    • Local Snapshots: If you are performing replication or back up to object storage, local snapshots must be created.
    • Replication: Creates replicated volumes on another ONTAP storage system.
    • Backup: Backs up volumes to object storage.
  2. Architecture: If you chose both replication and backup, choose one of the following flows of information:
    • Cascading: Information flows from the primary to the secondary, and then from the secondary to object storage.
    • Fan out: Information flows from the primary to the secondary and from the primary to object storage.
      For details about these architectures, refer to Plan your protection journey.
  3. Local Snapshot: Choose an existing snapshot policy or create a new one.
    Tip To create a custom policy, refer to Create a policy.
    To create a policy, select Create new policy and do the following:
    • Enter the name of the policy.
    • Select up to five schedules, typically of different frequencies.
    • Select Create.
  4. Replication: Set the following options:
    • Replication target: Select the destination system and storage VM. Optionally, select the destination aggregate or aggregates and prefix or suffix that will be added to the replicated volume name.
    • Replication policy: Choose an existing replication policy or create one.
      • Select Create.
  5. Back up to Object: If you selected Backup, set the following options:
    • Provider: Select StorageGRID.
    • Provider settings: Enter the provider gateway node FQDN details, port, access key and secret key.
      The access key and secret key are for the IAM user you created to give the ONTAP cluster access to the bucket.
    • Networking: Choose the IPspace in the ONTAP cluster where the volumes you want to back up reside. The intercluster LIFs for this IPspace must have outbound internet access (not required when the Console agent is installed in a "dark" site).
      Tip Selecting the correct IPspace ensures that NetApp Backup and Recovery can set up a connection from ONTAP to your StorageGRID object storage.
    • Backup policy: Select an existing Backup to object storage policy or create one.
      • For backup-to-object policies, set the DataLock and Ransomware protection settings. For details on DataLock and Ransomware protection, refer to Backup-to-object policy settings.
        If your cluster is using ONTAP 9.11.1 or greater, you can choose to protect your backups from deletion and ransomware attacks by configuring DataLock and Ransomware protection. DataLock protects your backup files from being modified or deleted, and ransomware protection scans your backup files to look for evidence of a ransomware attack in your backup files.
      • Select Create.
    If your cluster is using ONTAP 9.12.1 or greater and your StorageGRID system is using version 11.4 or greater, you can choose to tier older backups to public cloud archive tiers after a certain number of days. Current support is for AWS S3 Glacier/S3 Glacier Deep Archive or Azure Archive storage tiers. See how to configure your systems for this functionality.
    • Tier backup to public cloud: Select the cloud provider that you want to tier backups to and enter the provider details.
      Select or create a new StorageGRID cluster. For details about creating a StorageGRID cluster so the Console can discover it, refer to StorageGRID documentation.
    • Export existing snapshots to object storage as backup copies: If there are any local snapshots for volumes in this system that match the backup schedule label you just selected for this system (for example, daily, weekly, etc.), this additional prompt is displayed. Check this box to have all historic snapshots copied to object storage as backup files to ensure the most complete protection for your volumes.
  6. Select Next.
Review your selections
This is the chance to review your selections and make adjustments, if necessary.
Steps
  1. In the Review page, review your selections.
  2. Optionally check the box to Automatically synchronize the snapshot policy labels with the replication and backup policy labels. This creates snapshots with a label that matches the labels in the replication and backup policies.
  3. Select Activate Backup.
Result
NetApp Backup and Recovery starts taking the initial backups of your volumes. The baseline transfer of the replicated volume and the backup file includes a full copy of the source data. Subsequent transfers contain differential copies of the primary storage data contained in snapshots.
A replicated volume is created in the destination cluster that will be synchronized with the primary storage volume.
An S3 bucket is created in the service account indicated by the S3 access key and secret key you entered, and the backup files are stored there.
The Volume Backup Dashboard is displayed so you can monitor the state of the backups.
You can also monitor the status of backup and restore jobs using the Job Monitoring page.
You might want to display and optionally copy the API commands used in the Activate Backup and Recovery wizard. You might want to do this to automate backup activation in future systems.
Steps
  1. From the Activate Backup and Recovery wizard, select View API request.
  2. To copy the commands to the clipboard, select the Copy icon.
