SANtricity software
Export key management server certificates
You can save a certificate for a key management server to your local machine.
Before you begin
  • You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
  • Certificates must be previously imported.
Steps
  1. Select Settings › Certificates.
  2. Select the Key Management tab.
  3. From the table, select the certificate you want to export, and then click Export.
    A Save dialog box opens.
  4. Enter a filename and click Save.
