SANtricity software
Export key management server certificates in SANtricity System Manager
Contributors netapp-driley netapp-jolieg
You can save a certificate for a key management server to your local machine.
Before you begin
  • You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
  • Certificates must be previously imported.
Steps
  1. From the left panel, select Certificates › Key management certificates.
  2. From the table, select the certificate you want to export, and then click Export.
    A Save dialog box opens.
  3. Enter a filename and click Save.
