SANtricity software
Change the controller ownership of a volume in SANtricity System Manager
Contributors netapp-jolieg netapp-driley
You can change the preferred controller ownership of a volume, so that I/O for host applications is directed through the new path.
Before you begin
If you do not use a multipath driver, any host applications that are currently using the volume must be shut down. This action prevents application errors when the I/O path changes.
About this task
You can change controller ownership for one or more volumes in a pool or volume group.
Steps
  1. From the left panel, select Storage › Volumes.
  2. Click the ellipsis icon › Change volume ownership.
    The Change Volume Ownership window appears. All volumes on the storage array appear in this dialog box.
  3. Use the Preferred Owner drop-down list to change the preferred controller for each volume that you want to change, and confirm that you want to perform the operation.
Results
  • System Manager changes the controller ownership of the volume. I/O to the volume is now directed through this I/O path.
  • The volume might not use the new I/O path until the multipath driver reconfigures to recognize the new path. This action usually takes less than five minutes.
