Reconstruct a drive manually in SANtricity System Manager
Drive reconstruction normally starts automatically after you replace a drive. If drive reconstruction does not start automatically, you can start reconstruction manually.
Perform this operation only when instructed to do so by technical support or the Recovery Guru. |
Steps
From the left panel, select menu:Hardware[Drives].
Click the drive that you want to manually reconstruct.
The drive's context menu appears.
Select Reconstruct, and confirm that you want to perform the operation.
