Reconstruct drive manually
Drive reconstruction normally starts automatically after you replace a drive. If drive reconstruction does not start automatically, you can start reconstruction manually.
Perform this operation only when instructed to do so by technical support or the Recovery Guru. |
Steps
Select Hardware.
If the graphic shows the controllers, click Show front of shelf.
The graphic changes to show the drives instead of the controllers.
Click the drive that you want to manually reconstruct.
The drive's context menu appears.
Select Reconstruct, and confirm that you want to perform the operation.
