Update battery learn cycles in SANtricity System Manager
A learn cycle is an automatic cycle for calibrating the smart battery gauge. The cycles are scheduled to start automatically, at the same day and time, in 8-week intervals (per controller). If you want to set a different schedule, you can adjust the learn cycles.
About this task
Updating the learn cycles affect both controller batteries.
Steps
From the left panel, select menu:Hardware[Controllers and components].
Select the drop-down list for the Controller Shelf, and then select View settings.
Select the Batteries tab.
Select Update battery learn cycles.
The Update Battery Learn Cycles dialog box opens.
From the drop-down lists, select a new day and time.
Click Save.
