SANtricity software
Revoke access tokens in SANtricity System Manager
Contributors netapp-jolieg netapp-driley
You can revoke all access tokens if you determine that a token has been compromised or if you want to perform a manual key rotation for the cryptographic keys used to sign and validate the access tokens.
This operation regenerates the keys used to sign the tokens. Once the keys are reset, all issued tokens are immediately invalidated. Because the storage array does not track tokens, individual tokens cannot be revoked.
Steps
  1. From the left panel, select Authentication › Access tokens.
  2. Select Revoke All Access Tokens.
  3. In the dialog box, click Yes.
After revoking all tokens, you can create new tokens and use them immediately.
