SANtricity software
Monitor thin volumes
You can monitor thin volumes for space and generate appropriate alerts, so that you can prevent out-of-capacity conditions.
Note
This feature is not available on the EF600 or EF300 storage system.
Note
SANtricity System Manager does not provide an option to create thin volumes. If you want to create thin volumes, use the Command Line Interface (CLI).
