SANtricity software
Monitor thin volumes in SANtricity System Manager
You can monitor thin volumes for space and generate appropriate alerts, so that you can prevent out-of-capacity conditions.
Note
This feature is not available on the EF600/EF600C or EF300/EF300C storage system.
Note
SANtricity System Manager does not provide an option to create thin volumes. If you want to create thin volumes, use the Command Line Interface (CLI).
