Monitor thin volumes in SANtricity System Manager
You can monitor thin volumes for space and generate appropriate alerts, so that you can prevent out-of-capacity conditions.
This feature is not available on the EF80, EF50, EF600/EF600C, or EF300/EF300C storage system. |
SANtricity System Manager does not provide an option to create thin volumes. If you want to create thin volumes, use the Command Line Interface (CLI). |
