View iSCSI statistics packages
You can view data about the iSCSI connections to your storage array.
About this task
System Manager shows these types of iSCSI statistics. All statistics are read-only and cannot be set.
  • Ethernet MAC statistics — Provides statistics for the media access control (MAC). MAC also provides an addressing mechanism called the physical address or the MAC address. The MAC address is a unique address that is assigned to each network adapter. The MAC address helps deliver data packets to a destination within the subnetwork.
  • Ethernet TCP/IP statistics — Provides statistics for the TCP/IP, which is the Transmission Control Protocol (TCP) and Internet Protocol (IP) for the iSCSI device. With TCP, applications on networked hosts can create connections to one another, over which they can exchange data in packets. The IP is a data-oriented protocol that communicates data across a packet-switched inter-network. The IPv4 statistics and the IPv6 statistics are shown separately.
  • Local Target/Initiator (Protocol) statistics — Shows statistics for the iSCSI target, which provides block level access to its storage media, and shows the iSCSI statistics for the storage array when used as an initiator in asynchronous mirroring operations.
  • DCBX Operational States statistics — Displays the operational states of the various Data Center Bridging Exchange (DCBX) features.
  • LLDP TLV statistics — Displays the Link Layer Discovery Protocol (LLDP) Type Length Value (TLV) statistics.
  • DCBX TLV statistics — Displays the information that identifies the storage array host ports in a Data Center Bridging (DCB) environment. This information is shared with network peers for identification and capability purposes.
You can view each of these statistics as raw statistics or as baseline statistics. Raw statistics are all of the statistics that have been gathered since the controllers were started. Baseline statistics are point-in-time statistics that have been gathered since you set the baseline time.
Steps
  1. Select Settings  System.
  2. Select View iSCSI Statistics Packages.
  3. Click a tab to view the different sets of statistics.
  4. Optional: To set the baseline, click Set new baseline.
    Setting the baseline sets a new starting point for the collection of the statistics. The same baseline is used for all iSCSI statistics.
See the following sections for more information about the different types of statistics.
MAC transmit and MAC receive statistics
When you select Ethernet MAC statistics, both the receive and transmit statistics appear. You can view each of these statistics as raw statistics or as baseline statistics.
MAC transmit statistics:
Statistic Definition
F
Frame count
B
Byte count
MF
Multicast frame count
BF
Broadcast frame count
PF
Pause frame count
CF
Control frame count
FDF
Frame deferral count
FED
Frame excess deferral count
FLC
Frame late collisions count
FA
Frame abort count
FSC
Frame single collision count
FMC
Frame multiple collisions count
FC
Frame collision count
FDR
Frame dropped count
JF
Jumbo frame count
MAC receive statistics:
F
Frame count
B
Byte count
MF
BF
PF
Pause frame count
CF
Control frame count
FLE
Frame length error count
FD
Frame dropped count
FCRCE
Frame CRC error count
FEE
Frame encoding error count
LFE
Large frame error count
SFE
Small frame error count
J
Jabber count
UCC
Unknown control frame count
CSE
Carrier sense error count
When you select Ethernet TCP/IP statistics, both the TCP and IP statistics appear. You can view each of these statistics as raw statistics or as baseline statistics.
Ethernet TCP statistics:
TxS
Transmitted segment count
TxB
Transmitted byte count
RTxTE
Retransmit timer expired count
TxDACK
Transmit delayed ACK count
TxACK
Transmit ACK count
RxS
Received segment count
RxB
Received byte count
RxDACK
Received duplicate ACK count
RxACK
Received ACK count
RxSEC
Received segment error count
RxSOOC
Received segment out-of-order count
RxWP
Received window probe count
RxWU
Received window update count
Ethernet IP statistics:
TxP
Transmitted packet count
TxB
TxF
Transmitted fragment count
RxP
Packets received count. Select Show IPv4 to show the IPv4 packets received count. Select Show IPv6 to show the IPv6 packets received count.
RxB
Received byte count
RxF
Received fragment count
RxPE
Received packet error count
DR
Datagram reassembly count
DRE-OLFC
Datagram reassembly error, overlapped fragment count
DRE-OOFC
Datagram reassembly error, out-of-order fragment count
DRE-TOC
Datagram reassembly error, time-out count
iSCSI target statistics and local initiator statistics
When you select Target (protocol) statistics or Local initiator (protocol) statistics, the iSCSI statistics appear. You can view each of these statistics as raw statistics or as baseline statistics.
iSCSI statistics:
SL
Successful iSCSI login count
UL
Unsuccessful iSCSI login count
SA
Successful iSCSI authentication count (when authentication is enabled)
UA
Unsuccessful iSCSI authentication count (when authentication is enabled)
PDU
Correct iSCSI PDUs processed count
HDE
iSCSI PDUs with header digest errors count
DDE
iSCSI PDUs with data digest errors count
PE
PDUs with iSCSI protocol errors count
UST
Unexpected iSCSI session terminations count
UCT
Unexpected iSCSI connection termination count
DCBX operational state statistics
When you select Data Center Bridging Exchange (DCBX) Operational State Statistics, the DCBX statistics appear.
DCBX statistics:
iSCSI Host Port
Indicates the location of the detected host port in Controller #, Port # format.
Priority Group
Indicates the operational state of the Priority Group (PG) application. The state is either Enabled or Disabled.
Priority-based Flow Control
Indicates the operational state of the Priority-based Flow Control (PFC) feature. The state is either Enabled or Disabled.
iSCSI Feature
Indicates the operational state of the Internet Small Computer System Interface (iSCSI) application. The state is either Enabled or Disabled.
FCoE Bandwidth
Indicates the state of the Fibre Channel over Ethernet (FCoE) Bandwidth. The state is either True or False.
No FCoE/FIP Map Mismatch
Indicates whether a map mismatch exists between FCoE and FCoE Initialization Protocol (FIP). The value is either True or False.
Note You can find additional DCBX operational state statistics in the state capture file.
LLDP TLV statistics
When you select Link Layer Discovery Protocol (LLDP) Type Length Value (TLV) Statistics, two sets of statistics appear: one for the local device and one for the remote device. The local device refers to the controller. The remote device refers to the peer device that the controller is attached to, typically a switch.
LLDP TLV statistics:
iSCSI Host Port
Chassis ID
Indicates the chassis ID.
Chassis ID Subtype
Indicates the chassis ID subtype.
Port ID
Indicates the port ID.
Port ID Subtype
Indicates the port ID subtype.
Time to Live
Indicates the number of seconds that the recipient LLDP agent considers the information to be valid.
Note You can find additional LLDP TLV statistics in the state capture file.
DCBX TLV statistics
When you select Data Center Bridging Exchange (DCBX) Type Length Value (TLV) Statistics, these statistics appear:
  • Local statistics — The DCBX parameters configured on the controller at the factory.
  • Operational statistics — The DCBX parameters that result from DCBX negotiations.
  • Remote statistics — The DCBX parameters from the peer device that the controller is connected to, typically a switch.
DCBX TLV statistics:
iSCSI Host Port
Flow Control Mode
The Flow Control Mode of the entire port. Valid values are Disabled, Standard, Per Priority, or Indeterminate.
Protocol
The communication protocol. Valid values are FCoE, FIP, iSCSI, or UNKNOWN.
Priority
Integer value indicating the priority number of the communication.
Priority Group
Integer value representing the priority group to which the protocol has been assigned.
Priority Group % Bandwidth
Percentage value indicating the amount of bandwidth allocated to the priority group.
DCBX PFC Status
Priority-based Flow Control (PFC) status of the specific port. The value is either enabled or disabled.
Note You can find additional DCBX TLV statistics in the state capture file.
