Element Software
View information about system events
Contributors netapp-pcarriga
You can view information about various events detected in the system. The system refreshes the event messages every 30 seconds. The event log displays key events for the cluster.
  1. In the Element UI, select Reporting > Event Log.
    For every event, you see the following information:
    Item
    ID
    Unique ID associated with each event.
    Event Type
    The type of event being logged, for example, API events or clone events.
    Message
    Message associated with the event.
    Details
    Information that helps identify why the event occurred.
    Service ID
    The service that reported the event (if applicable).
    Node
    The node that reported the event (if applicable).
    Drive ID
    The drive that reported the event (if applicable).
    Event Time
    The time the event occurred.
Find more information
