Element Software
Access per-node settings using the per-node UI
Contributors netapp-pcarriga
You can access network settings, cluster settings, and system tests and utilities in the per-node user interface after you enter the management node IP and authenticate.
If you want to modify settings of a node in an Active state that is part of a cluster, you must log in as a cluster administrator user.
Tip You should configure or modify one node at a time. You should ensure that the network settings specified are having the expected effect, and that the network is stable and performing well before you make modifications to another node.
  1. Open the per-node UI using one of the following methods:
    • Enter the management IP address followed by :442 in a browser window, and log in using an admin user name and password.
    • In the Element UI, select Cluster > Nodes, and click the management IP address link for the node you want to configure or modify. In the browser window that opens, you can edit the settings of the node.
    Per node UI network settings page
