Element Software
Change credentials in NetApp HCI and NetApp SolidFire
Contributors netapp-pcarriga
Depending on the security policies in the organization that deployed NetApp HCI or NetApp SolidFire, changing credentials or passwords is commonly part of the security practices. Before you change passwords, you should be aware of the impact on other software components in the deployment.
If you change credentials for one component of a NetApp HCI or NetApp SolidFire deployment, the following table provides guidance as to the impact on other components.
NetApp SolidFire component interactions: NetApp SolidFire components
Credential Type and Icon Usage by Admin See these instructions
Element credentials
Red lock icon
Applies to: NetApp HCI and SolidFire
Admins use these credentials to log into:
  • Element user interface on the Element storage cluster
  • Hybrid Cloud Control on the management node (mnode)
When Hybrid Cloud Control manages multiple storage clusters, it accepts only the admin credentials for the storage clusters, known as the authoritative cluster that the mnode was initially set up for. For storage clusters later added to Hybrid Cloud Control, the mnode securely stores admin credentials. If credentials for subsequently added storage clusters are changed, the credentials must also be updated in the mnode using the mnode API.
vSphere Single Sign-on credentials
Light green lock icon
Applies to: NetApp HCI only
Admins use these credentials to log into the VMware vSphere Client. When vCenter is part of the NetApp HCI installation, credentials are configured in the NetApp Deployment Engine as the following:
  • username@vsphere.local with the specified password, and
  • administrator@vsphere.local with the specified password. When an existing vCenter is used to deploy NetApp HCI, the vSphere Single Sign-on credentials are managed by the IT VMware admins.
Baseboard management controller (BMC) credentials
Black lock icon
Administrators use these credentials to log in to the BMC of the NetApp compute nodes in a NetApp HCI deployment. The BMC provides basic hardware monitoring and virtual console capabilities.
BMC (sometimes referred to as IPMI) credentials for each NetApp compute node are stored securely on the mnode in NetApp HCI deployments. NetApp Hybrid Cloud Control uses BMC credentials in a service account capacity to communicate with the BMC in the compute nodes during compute node firmware upgrades.
When the BMC credentials are changed, the credentials for the respective compute nodes must be updated also on the mnode to retain all Hybrid Cloud Control functionality.
ESXi credentials
Dark green lock icon
Admins can log into ESXi hosts using either SSH or the local DCUI with a local root account. In NetApp HCI deployments, the username is 'root' and the password was specified during the initial installation of that compute node in NetApp Deployment Engine.
ESXi root credentials for each NetApp compute node are stored securely on the mnode in NetApp HCI deployments. NetApp Hybrid Cloud Control uses the credentials in a service account capacity to communicate with ESXi hosts directly during compute node firmware upgrades and health checks.
When the ESXi root credentials are changed by a VMware admin, the credentials for the respective compute nodes must be updated on the mnode to retain Hybrid Cloud Control functionality.
QoS integration password
Purple lock icon
Applies to: NetApp HCI and optional in SolidFire
Not used for interactive logins by admins.
The QoS integration between VMware vSphere and Element Software is enabled via:
  • Element Plug-in for vCenter Server, and
  • QoS service on the mnode.
For authentication, the QoS service uses a password that is exclusively used in this context. The QoS password is specified during the initial installation of the Element Plug-in for vCenter Server, or auto-generated during NetApp HCI deployment.
No impact on other components.
The NetApp Element Plug-in for vCenter Server SIOC password is also known as the QoSSIOC password
vCenter Service Appliance credentials
Dark gray lock icon
Applies to: NetApp HCI only if set up by NetApp Deployment Engine
Admins can log into the vCenter Server appliance virtual machines. In NetApp HCI deployments, the username is 'root' and the password was specified during the initial installation of that compute node in the NetApp Deployment Engine. Depending on the VMware vSphere version deployed, certain admins in the vSphere Single Sign-on domain can also log in to the appliance.
No changes needed.
NetApp Management Node admin credentials
Light gray lock icon
Admins can log into the NetApp management node virtual machines for advanced configuration and troubleshooting. Depending on the management node version deployed, login via SSH is not enabled by default.
In NetApp HCI deployments, the username and  password was specified by the user during the initial installation of that compute node in NetApp Deployment Engine.
No changes needed.
