View Fibre Channel sessions
PDF of this doc site
Manage storage with Element software
Creating your file...
Your file is ready
You can view the Fibre Channel (FC) sessions that are connected to the cluster. You can filter information to include only those connections you want displayed in the window.
In the Element UI, select Reporting > FC Sessions.
To see the filter criteria fields, click Filter.
