Learn about Google Cloud NetApp Volumes deployment options for Oracle Database 26ai
Google Cloud NetApp Volumes supports Oracle Database 26ai across multiple deployment tiers, from dev/test environments to production high availability configurations with Data Guard and Fast-Start Failover. Review deployment requirements, compare HA tiers, and identify the task sequence for your chosen architecture on Google Cloud NetApp Volumes.
Deployment requirements
Ensure that you have the following items in place before provisioning Google Cloud NetApp Volumes for Oracle Database 26ai high availability:
A Google Cloud project with permissions for Compute Engine, VPC networking, firewall configuration, IAM, and NetApp Volumes
Task Required access Create Compute Engine VMs
Compute Instance Admin (or equivalent)
Firewall / Firewall Policies
Network Admin or delegated policy admin
Create GCNV pools and volumes
NetApp Volumes Admin
Configure PSA
Network admin in host project
SSH via IAP
IAP-secured Tunnel User + OS Login (if used)
The NetApp Volumes API enabled
A VPC and subnet configured for the target region
Private Services Access (PSA) configured for Google Cloud NetApp Volumes
Oracle Linux 10 for all required virtual machines
DNS and hostname resolution is configured for the database hosts and Observer host
Oracle installation media and patch files available for Oracle Database 26ai and Grid Infrastructure
Familiarity with Oracle Data Guard, Oracle Restart, and iSCSI storage concepts
Time synchronization is configured for all virtual machines.
You can use the following commands:
gcloud services enable netapp.googleapis.com chronyc tracking timedatectl
Example deployment configuration
This solution uses the following deployment configuration:
Three Google Compute Engine virtual machines:
oracdb1for the primary database -
oracdb2for the standby database -
oradg-obsfor the Fast-Start Failover Observer
One GCNV Flex Unified storage pool per database zone
Five GCNV iSCSI volumes per database host
Oracle Data Guard Broker and Fast-Start Failover for automatic failover
Dedicated storage per database host; primary and standby hosts do not share iSCSI volumes
Replace all example values in the commands with values from your environment, including host names, IP addresses, zones, project names, portal IPs, passwords, and Oracle media file names.
Deployment options
The following table compares HA and DR deployment patterns and highlights where automation provides the most operational benefit.
| Environment | Requirement | Recommended architecture | HA | DR | Automation | Key benefit |
Dev/Test |
Lowest cost |
Single instance |
No |
Yes |
No |
Snapshot clone |
Prod Basic (Restart) |
Reduce downtime from crashes |
+ Oracle Restart |
No |
Yes |
Local only |
Auto-restart |
Prod HA (no DG) |
Manual DR acceptable |
+ Snapshots / RMAN |
Partial |
Yes |
Partial |
GCNV clone recovery |
Prod HA (DG + FSFO) |
True HA (no DBA) |
Data Guard + FSFO |
Yes |
Yes |
Full |
True HA + fast failover |
Yes = meets tier goal
No = not in scope
Partial = storage-level or manual steps only
Deployment tasks by HA tier
The deployment workflow provides a numbered step sequence for all deployment tiers. All tiers complete the base deployment tasks shown below, then add tier-specific tasks for production high availability:
Base deployment (all tiers):
Review deployment options and requirements (this page)
Tier-specific tasks (Prod HA only):
| Tier | Deployment steps |
Dev/Test and Prod Basic (Restart) tiers |
Complete base deployment Step 1 through Step 7 only. No standby database is required. |
Prod HA (no Data Guard) |
Complete base deployment Step 1 through Step 8. |
Prod HA (Data Guard + FSFO) |
Complete all base deployment steps, then add: |
What's next?
To prepare your environment before deployment, continue with Access and APIs for Oracle Database 26ai on Google Cloud NetApp Volumes.
