What's new in NetApp solutions for SAP
Learn what's new in solutions for SAP.
12 August 2026
New Solution SAP HANA data protection with SnapCenter using VMware VMFS and SnapMirror active sync on NetApp ASA R2. The best practices for data protection using SnapCenter for HANA systems running on VMware with datastores using VMFS and LUNs stored on NetApp ASAr2 systems using SnapMirror active sync are outlined in this document.
05 August 2026
New solution NetApp SnapCenter for SAP HANA on bare metal servers with NetApp ASA systems provides best practices for SAP HANA data protection with NetApp SnapCenter, covering SnapCenter configuration and operation guidelines for protecting SAP HANA systems on ONTAP ASA systems with bare metal servers.
26 February 2026
Updated Automating SAP HANA System Copy and Clone Operations with SnapCenter solution to cover SAP HANA volume encryption with local secure store (LSS).
Updated SAP HANA Backup and Recovery with SnapCenter solution to cover SAP HANA volume encryption with local secure store (LSS) as well as new supported configurations.
02 December 2025
New solution: SAP HANA backup and recovery with SnapCenter
This solution provides best practices for SAP HANA data protection with NetApp SnapCenter, covering SnapCenter configuration and operation guidelines for protecting SAP HANA systems on ONTAP AFF and ASA systems, Azure NetApp Files, and Amazon FSx for ONTAP.
12 November 2025
New solution SAP HANA with SUSE KVM and NetApp Storage:
Deploy SAP HANA Single-Host on SUSE KVM using NetApp storage with SR-IOV network interfaces and NFS or FCP storage access.
18 August 2025
The NetApp Solutions site is now the NetApp solutions family, which includes the following sites:
