Tiering data from on-premises ONTAP clusters to Amazon S3
Free space on your on-prem ONTAP clusters by tiering data to Amazon S3. Data tiering is powered by NetApp's Cloud Tiering service.
Quick start
Get started quickly by following these steps or scroll down to the remaining sections for full details.
Prepare to tier data to Amazon S3
You need the following:
An AFF or FAS system with all-SSD aggregates that's running ONTAP 9.2 or later and has an HTTPS connection to Amazon S3.
An AWS account that has an access key and the required permissions so the ONTAP cluster can tier inactive data in and out of S3.
A Connector installed in an AWS VPC or on your premises.
Networking for the Connector that enables an outbound HTTPS connection to the ONTAP cluster, to S3 storage, and to the Cloud Tiering service.
Set up tiering
In Cloud Manager, select an on-prem working environment, click Setup Tiering and follow the prompts to tier data to Amazon S3.
Set up licensing
After your free trial ends, pay for Cloud Tiering through a pay-as-you-go subscription, an ONTAP tiering license, or a combination of both:
To subscribe from the AWS Marketplace, click Tiering > Licensing, click Subscribe, and then follow the prompts.
To pay using a tiering license, contact us if you need to purchase one, and then add it to your cluster from Cloud Tiering.
Requirements
Verify support for your ONTAP cluster, set up your networking, and prepare your object storage.
The following image shows each component and the connections that you need to prepare between them:
Communication between a Connector and S3 is for object storage setup only. The Connector can reside on your premises, instead of in the cloud. |
Preparing your ONTAP clusters
Your ONTAP clusters must meet the following requirements when tiering data to Amazon S3.
- Supported ONTAP platforms
Cloud Tiering supports AFF systems and all-SSD aggregates on FAS systems.
- Supported ONTAP version
ONTAP 9.2 or later
- Cluster networking requirements
The ONTAP cluster initiates an HTTPS connection over port 443 to Amazon S3.
ONTAP reads and writes data to and from object storage. The object storage never initiates, it just responds.
Although AWS Direct Connect provides better performance and lower data transfer charges, it's not required between the ONTAP cluster and S3. Because performance is significantly better when using AWS Direct Connect, doing so is the recommended best practice.
An inbound connection is required from the Connector, which can reside in an AWS VPC or on your premises.
A connection between the cluster and the Cloud Tiering service is not required.
An intercluster LIF is required on each ONTAP node that hosts tiered volumes. The LIF must be associated with the IPspace that ONTAP should use to connect to object storage.
IPspaces enable network traffic segregation, allowing for separation of client traffic for privacy and security. Learn more about IPspaces.
When you set up data tiering, Cloud Tiering prompts you for the IPspace to use. You should choose the IPspace that each LIF is associated with. That might be the "Default" IPspace or a custom IPspace that you created.
Unresolved directive in task_tiering_onprem_aws.adoc - include::https://raw.githubusercontent.com/NetAppDocs/cloud-tiering/master/_include/supported_volumes.adoc[]
Cloud Tiering supports FlexGroup volumes, starting with ONTAP 9.5. Setup works the same as any other volume. |
Creating or switching Connectors
A Connector is required to tier data to the cloud. When tiering data to AWS S3, you can use a Connector that's in an AWS VPC or on your premises. You'll either need to create a new Connector or make sure that the currently selected Connector resides in AWS or on-prem.
Preparing networking for the Connector
Ensure that the Connector has the required networking connections. A Connector can be installed on-prem or in AWS.
Ensure that the network where the Connector is installed enables the following connections:
An outbound internet connection to the Cloud Tiering service over port 443 (HTTPS)
An HTTPS connection over port 443 to S3
An HTTPS connection over port 443 to your ONTAP clusters
If needed, enable a VPC Endpoint to S3.
A VPC Endpoint to S3 is recommended if you have a Direct Connect or VPN connection from your ONTAP cluster to the VPC and you want communication between the Connector and S3 to stay in your AWS internal network.
Preparing Amazon S3
When you set up data tiering to a new cluster, you're prompted to create an S3 bucket or to select an existing S3 bucket in the AWS account where the Connector is set up.
The AWS account must have permissions and an access key that you can enter in Cloud Tiering. The ONTAP cluster uses the access key to tier data in and out of S3.
Provide the following permissions to the IAM user:
"s3:ListAllMyBuckets", "s3:ListBucket", "s3:GetBucketLocation", "s3:GetObject", "s3:PutObject", "s3:DeleteObject"
Create or locate an access key.
Cloud Tiering passes the access key on to the ONTAP cluster. The credentials are not stored in the Cloud Tiering service.
Tiering inactive data from your first cluster to Amazon S3
After you prepare your AWS environment, start tiering inactive data from your first cluster.
An AWS access key for an IAM user who has the required S3 permissions.
Select an on-prem cluster.
Click Setup Tiering.
You're now on the Tiering dashboard.
Click Set up Tiering next to the cluster.
Complete the steps on the Tiering Setup page:
S3 Bucket: Add a new S3 bucket or select an existing S3 bucket that starts with the prefix fabric-pool and click Continue.
The fabric-pool prefix is required because the IAM policy for the Connector enables the instance to perform S3 actions on buckets named with that exact prefix.
For example, you could name the S3 bucket fabric-pool-AFF1, where AFF1 is the name of the cluster.
Storage Class: Select the S3 storage class that you want to transition the data to after 30 days and click Continue.
If you choose Standard, then the data remains in that storage class.
Credentials: Enter the access key ID and secret key for an IAM user who has the required S3 permissions.
The IAM user must be in the same AWS account as the bucket that you selected or created on the S3 Bucket page.
Cluster Network: Select the IPspace that ONTAP should use to connect to object storage and click Continue.
Selecting the correct IPspace ensures that Cloud Tiering can set up a connection from ONTAP to your cloud provider's object storage.
Click Continue to select the volumes that you want to tier.
On the Tier Volumes page, set up tiering for each volume. Click the
icon, select a tiering policy, optionally adjust the cooling days, and click Apply.
You've successfully set up data tiering from volumes on the cluster to S3 object storage.
You can also add additional clusters or review information about the active and inactive data on the cluster. For details, see Managing data tiering from your clusters.
