ONTAP commands
volume snapshot restore
Restore the volume to a snapshot.
The volume snapshot restore command restores a snapshot to be the read-write parent volume for the volume family. This replaces the current working copy of the volume with the snapshot that results in a loss of all changes made since the snapshot was created.
Note You should manually update all the SnapMirror relationships of a volume immediately after you restore its snapshot. Not doing so can result in unusable SnapMirror relationships that must be deleted and re-created.
After the restore is complete, the size of the flexible volume will be set to either the current volume size or the snapshot size - whichever is greater.
-vserver <vserver name> - Vserver
This specifies the Vserver that contains the volume on which the specified snapshot to be restored is saved.
-volume <volume name> - Volume
This specifies the parent read-write volume whose snapshot is to be restored to take its place.
-snapshot <snapshot name> - Snapshot
This specifies the snapshot that is to be restored to be the read-write parent volume.
[-force <true>] - Force Restore
If you use this parameter, the snapshot is restored even if the volume has one or more newer snapshots which are currently used as reference snapshot by SnapMirror. If a restore is done in this situation, this will cause future SnapMirror transfers to fail. The SnapMirror relationship may be repaired using snapmirror resync command if a common snapshot is found between the source and destination volume. If there is no common snapshot between the source and the destination volume, a baseline SnapMirror copy would be required. If you use this parameter, the operation is also allowed on application tagged volumes.
[-preserve-lun-ids {true|false}] - Preserve LUN Identifiers
This option enables you to select whether the snapshot restore needs to be non-disruptive to clients due to LUN or NVMe namespace identifiers changing. If you use this option and set it to true , or choose to not use this option at all, the volume snapshot restore command fails if the system determines that it cannot be non-disruptive with regards to LUN or NVMe namespace identifiers. If you use this option and set it to false , the restore operation proceeds even if this might cause client-visible effects. In this case, administrators should take the LUNs or NVMe namespaces offline before proceeding.
The following example restores a snapshot named vol3_snap_archive to be the parent read-write volume for the volume family. The existing read-write volume is named vol3 and is located on a Vserver named vs0:
cluster1::> volume snapshot restore -vserver vs0 -volume vol3
-snapshot vol3_snap_archive
