vserver iscsi security delete
Delete the iSCSI authentication configuration for an initiator
This command removes the security settings for this initiator. The default authentication setting now applies to this initiator.
- -vserver <Vserver Name>- Vserver
Specifies the Vserver.
- -i, -initiator-name <text>- Initiator Name
Specifies the initiator that you want to remove the authentication setting from.
cluster1::> vserver iscsi security delete -vserver vs1 -initiator-name iqn.1992-08.com.example:abcdefg
Deletes initiator iqn.1992-08.com.example:abcdefg on Vserver vs1 from the authentication setting. The default authentication now applies to this initiator.
 PDFs
PDFs
