Command reference
system switch ethernet threshold show
Display the Ethernet switch health monitor alert thresholds
The system switch ethernet threshold show command displays thresholds used by health monitor alerts.
cluster1::> system switch ethernet threshold show
    Errors/Utilization Threshold is per 0.10% values: 1 = 0.10%, 5 = 0.50%
    Entity-alert Threshold is the count needed to raise entity warning alert
Errors            Bandwidth
    Threshold (0.1%)  Threshold (0.1%)  Entity-alert
    In       Out      In       Out      Threshold
           1        1      900      900            2
Displays the inbound and outbound switch interface packet error thresholds which are set at 0.1%, and the inbound and outbound switch interface bandwidth utilization thresholds which are set at 90%. Also displays the threshold value for entity warning alerts. The node platform health monitor also shares the same thresholds for monitoring cluster port packet errors on the node.
