Command reference
volume clone quiesce-lun start
Quiesce a LUN during non-disruptive data migration
The volume clone quiesce-lun start command initiates LUN quiescence for the specified LUN. To end the quiescence process, use the volume clone quiesce-lun stop command. You can monitor the current status using the volume clone quiesce-lun show command.
-vserver <Vserver Name> - Vserver Name (privilege: advanced)
This parameter specifies the Vserver that the volume exists on.
{ -path <path> - LUN Path (privilege: advanced)
Specifies the path of the LUN. The LUN path cannot contain any files.
| -volume <volume name> - Volume Name (privilege: advanced)
This parameter specifies the volume that the LUN exists on.
[-qtree <qtree name>] - Qtree Name (privilege: advanced)
Specifies the qtree that contains the LUN.
-lun <text> - LUN Name (privilege: advanced) }
This parameter specifies the LUN name which will be quiesced during data migration.
The following example starts to quiesce the LUN lun1 on Vserver vs1 :
cluster1::> volume clone quiesce-lun start -vserver vs1 -path /vol/v1/lun1
