security oidc delete
Delete OIDC Client Configuration
The security oidc delete command deletes an OpenID Connect (OIDC) client configuration. This command does not disable the OIDC feature, it only removes the OIDC client configuration. To disable the OIDC feature, use the security oidc modify-enabled false command.
Disabling OIDC restarts the web server. Any HTTP/S connections that are active will be disrupted. |
The following example deletes the OIDC client configuration.
cluster1::> security oidc delete
