Command reference
storage iswi initiator delete
Remove software iSCSI initiator
This command deletes the software iSCSI initiator. Note: You must first delete all sessions associated with this initiator with storage iswi initiator session delete command before you can delete the initiator.
-node <nodename> - Node (privilege: advanced)
This parameter describe in which node initiator to be deleted.
-initiator-name <text> - Initiator Name (privilege: advanced)
The user defined initiator to be deleted.
arunhcluster-2::> storage iswi initiator delete -initiator-name iswi1
