diskown.shareddsk events
Creating your file...
Your file is ready
diskown.sharedDsk.nonHACfg
- Severity
ERROR
- Description
This message occurs when a disk is shared by multiple nodes in a non-HA or stand-alone configuration. If the procedure to convert an HA configuration to a non-HA configuration is not followed properly, the system may end up either having disks whose partitions are owned by another node, or owning partitions on non-local disks.
- Corrective Action
Refer to the High-Availability Configuration Guide.
- Syslog Message
Either some local disks have partitions that are not owned by the local node, or the local node owns partitions on non-local disks.
- Parameters
(None).
